A55 Smoothing Plane
brace chuck-chuck parts...
RogerC
>Hello,
I have 2 chucks that fit into a standard brace that lets you use round and hex bits.
The small one works great, but the "pyramidal" part of the large one is broken off.
Do any of you know where I could get a replacement?
It is 1/2" in diameter, 24 TPI, and requires a minimum of 1 3/4" of threads.
The shaft of the smaller one can be used in the bigger one, but its length isn't sufficient to allow the use of smaller bits.
Any leads would be helpful.
Re: brace chuck-chuck parts...
Do you have a friend who welds?
>This probably would not be hard to make if you've got a friend who welds - 1/2" by 24 threads per inch is a standard American Fine thread, and there are plenty of clapped-out auger bits around to serve as donors for the square taper.
If you don't have a friend with welding skills, you might contact the local community college, to see if a student in their welding classes would see this as a useful challenge.
Re: Do you have a friend who welds?
ThomD
>Just from the look of the thing, in the picture it looks like the remaining shank might be sufficient for the required job. If all that material out the rear end is surplus, you could chuck that baby into a woodworking lathe or fasten it to a dowel held in you drill press, and use a round file to turn the hourglass in there. Then hold it against a grinder, or better still a belt sander, to get the tapered shank. It is only a given section of that shank that will really mater. Obviously there a machinist ways of doing this, but i;m guessing if you had those machines you wouldn't be asking.
Another option, again that can be done in a woodworking lathe or a drill is to center drill a hole in the shank, and then insert a piece of square from some other source like a spade drill. Silver hard solder in place, or weld.
RogerC
>I have considered the welding and machining options, but I was hoping that there was a cheap ready-made alternative.
I got the feeling that I'm a few decades too late.
paul womack
>I have one of these, but (in practice) VERY rarely use it.
Small drill bits don't need the torque of a brace, but do need high RPM.
In short, egg beaters with twist bits for small holes, braces with augers for large holes.
BugBear
