Another "why did they stop making this?" tool
>John Jesseph was recently kind enough to sell me a Kelly Tool Works cigar shave, part of tool simplification on his part. It solves precisely the problem I've had with my metal shaves (and that I'm not sure is easily solved with wood shaves, though that comment will probably start off a long thread...): shaving tight inside corners. This little critter will make clean end grain cuts on pine in a 1/2" radius corner. I was concerned that it would be hard to use - round-soled shaves are said to be hard to use, something I wouldn't know because my Kunz shave is so funky I've never been able to start using it - but it didn't take long to learn how to get a good cut going.
I mostly push my other metal shaves, but this one is clearly a pull shave.
Apparently, they're temporarily out of production, while Tim Kelly moves his shop, so I'm sure glad John was willing to part with his.
It's a little hard to store - you can't retract the blade - I think I'll find some large ID rubber hose and slit it to make a cover.
When I get past shop work in thirty or forty years (optimism at work there - I turn 60 this year), I hope I'm still coherent enough to write up notes so my kids/grandkids don't throw out tools, not knowing what they do...
