Kicking it - old school
ThomD
>I bought a foot operated mortising machine. It isn't exactly as I remember the others I have seen here, but it looks serious enough to work, and apparently has had a long life in a sash shop already. The cutting action is a vertical plunge, while the chisel can be rotated through 180. If my hands were restricted to those motions I would most likely alternate strokes, keeping the bevel on the outside, until I had dug out a v shaped notch within the layout. Then I would alternate cuts with the bevel inside to widen the notch into a square pocket. There isn't any capacity to pry chips out, at least not with the machine.
The only thing that bothers me about this proceedure is that it seems a little busy as far as all the 180s are concerned. Can anyone describe a sensible proceedure, I haven't seen this kind of tool in action?
I bought it mostly because a machine of this general type is one of my father's main memories of his father's workshop.
