Almost done my hand tool cabinet
Dominic Greco in Richboro PA
>Hi everyone,
Here are some photos of my progress with my hand tool cabinet project.
I completed and attached the doors with piano hinges. The doors are just 3" deep boxes with dovetailed joints. They each have a 1/2" thick plywood panel.
The infamous "reverse dovetail" drawers were installed as well. They got stopped dados cut in the sides and poplar drawer slides were installed for them to ride on. The drawer pulls are walnut and were turned on the lathe. I WAS going to buy them but couldn't find ones that were the right size. It only took me 6 to 10 minutes a drawer pull to complete each one (I made 16. 4 extra in case I screwed up!)
I need to install a small cover plate in the front that is about 2" wide and as tall as the doors. This will cover the gap between the doors when they're closed. Mostly it's a retainer for when I add the lock. The Gap Plate (as I'm calling it) will have a 3/8" wide strip on walnut inlayed down the center. This will break up the doors and make it more symmetrical. It will give the illusion that there is no break in the lines of the doors. I cut the rabbit and glued the walnut in place tonight.
I need to cut and install the french cleats. Then I will sand and seal the entire thing. After that I'll give it a couple coats of wipe on poly and hang it. Then I can work on the tool/plane holders.
tool cabinet drawers
tool cabinet 2
tool cabinet1
See ya around,
Dominic
Re: Almost done my hand tool cabinet
James Watriss
>Looks fantastic!
Can't wait to see it finished, and hung...
Victor Parisian
>Looking good Dom.
What are the overall dimensions?
Looks like it should hold a lot of tools.
Victor - getting back to work in H&HH (Hot and Humid Houston)
Hank Knight
>Wow, Dom! That's really nice. Lots of storage room. I like the spalted drawer fronts and the grain match. Super work! I have been thinking about building one myself. You may be my inspiration - as soon as I finish my current project for LOML. I can't wait to see your finished cabinet on the wall and stocked with tools.
Hank
>Thanks for the kind words. The cabinet is approx 43" high x 52" wide x 10" deep. The doors add another 3 1/2" to the depth.
Great job, Dom...
Ted Owen, Pittsburgh
>Nice to see that on your middle column of drawers you placed two pulls off-center for each drawer front. Not thinking (saying it myself before anyone else does), I placed mine in the center of the drawer fronts. And now they keep the front doors from closing. Sheesh.
Best, Ted
Stuart Hough
>Gorgeous work, Dom! The "infamous reverse dovetails" are a great design feature. It seems to me that with the resulting glue area, there really won't be any issues with separation, though I'm sure you've already figured that. My guess is it would take a bunch more weight than you are planning on in the drawers to make them start coming apart. Make sure you post a picture of the chest once it's mounted, so we can drool all over again!
Dave Anderson NH
>It's coming along nicely Dominic. I'll warn your right now though, get some help when it comes time to hang it. It's not a question of the weight, the depth really makes it awkward to handle. Been there, done that.
>Thanks for the compliment!
Oh, I hear you about getting help to hang it. My buddy here at work is scheduled to help me re-arrange the shop and hang this cabinet. There is NO way I could lift this puppy by myself. It's not that it's too heavy. And like you said, it's the overall SIZE that makes it awkward.
Fantastic Dom!
Scott Burr in Ben Lomond, CA
>It's really coming together! That's going to be a great addition to your shop. I like how the the DT's look now that the cabinet is almost complete. Good work!
charlie belden, san jose, CA
>Dominic:
Love the drawers - including the "creative" dovetails. Nice figure flow acrossed them. Always not as easy as it seems initially to get that flow. Shallow drawers prevent "the pile up then dig through to find things" unforeseen problem.
Those are pretty wide doors, and even with full length piano hinges, that's going to limit how much stuff you can put in the doors. Great place for chisel racks you can remove and take to the bench. Also good for holding hand saws, though working out how to hold them in place, yet get them out easily can be a fun puzzle to work out.
Given the size of your cabinet, and the weight you'll be putting in it, I'd go with top AND bottom french cleats (belt AND suspenders) .
Are you going to store your hand planes on their soles on the shelves or in the "pigeon holes"?
Consider insert modules in the cabinet. You can store an amazing number of tools in not a lot of space - if you're good at puzzles. And if you use dovetails and sliding dovetails you can put things together without glue - leaving options for future changes - which I'm sure there will be.
Look foreward to pics of the completed, hung and filled cabinet.
charliel belden
Nice....Great Job, Dom!
Eddie Pacheco; San Jose, Ca.
