Making a 6 panel door
Bill Tindall, E.TN
>Maybe it is a retirement thing but I find I am reluctant to buy anything I can make now days. I like a panel door with a large rise on the panel part and such a door is not to be found in doors at Lowe's. They can be special ordered, $$$, I have made all sorts of raised panels for furniture and cabinets, so why not a closet door?
Now my friend has a door set for his shaper that makes short work of making a door. I have been waiting 10 years for him to get the bushings to be able to make a thinner door like for closets, rather than the 1 3/4 doors he makes. So, I had-at making the doors with tools at hand. About the only secret beyond what is already needed to make a frame and panel for a cabinet door is to find straight vertical pieces. The door is painted 1 1/8" thick poplar. I turned the knobs. The door is held shut by some unobtrusive LV magnets in the top of the door stop.
I don't have a vast plane collection, so I use my shoulder plane for smoothing the bevels on the panels. I like doing finish carpentry work the old fashion way. I have fond memories of my Uncle Ed fitting a door with a hand plane. I would collect the curly shavings.
I have a collection of hand drills for pilot holes for the poplar trim installation. I can chop out the hinge mortices reliably and there is less mess to deal with. They fit snug (I do use a home made jig and router if there are a lot to do.) BTW, the trim is a Canadian pattern I fond on something years ago and traced in anticipation of building another house some day. (I had it run at a local shop; I for sure didn't cut several hundred feet of it by hand)
Re: Making a 6 panel door
Wiley Horne -- So. Calif.
>Bill,
That's really beautiful work! I have a question about the small interior mouldings on the insides of the rails and stiles--the ones that border the panels.
Do you like to miter and apply those? Or are they stuck? And if they are stuck, are they mitered or scribed? Whatever detail you can provide on how those are done would be appreciated. Now if you had had one of those Tidey planes.....
Wiley
Well Done!
Scott Burr in Ben Lomond, CA
>They look great Bill! How did you do the raised the panels?
false cope
Bill Tindall, E.TN
>see response on main message board. I like this joint. When it is not a painted door I make them better than in the picture.
electrons
Bill Tindall, E.TN
>lay board flat on table and saw the outline of the panel field. Tip board on edge and with aid of two fences to capture panel to keep it from wiggling, saw bevel. Clean up bevel with shoulder plane.
Re: false cope
>That's a very useful joint Bill. If I understand it, it sounds like the horizontal and vertical mouldings are mitered in such a way that one of them slides over the other to make the pattern match. Instead of butting up against each other, one laps over the other, so no gap can open up.
Wiley .... thinking he gets it
