Need help with a small gloat
Tom MacGregor
>Some neighbors were having a yard sale and asked me if I wanted first dibs an a "weird tool thing-a-ma-jiggy" for two bucks. It's an adjustable hollow auger, 3/8 to 1" holes, complete with all original parts & screws, 90% finish and a (probably) near full length blade. It's marked "BONNEY'S PAT Feb 2 70". Can anyone describe how to use one of these things? My first try resulted in nothing but a spiral scored down the dowel instead of a tenon.
Re: Need help with a small gloat
Well Done
David Miller from Iowa
>Nice catch. This cuts a shoulder on a piece larger than the diameter of the opening. These work really well provided you have the corollary tool � the spoke pointer. You need to start working on a cone shaped piece and it should go well. Presuming your cutter is sharp and set for a shallow cut.
Good luck. David
