On making a curved top from staves *LINK*
Bill Tindall, E.TN
>If all is well the link will connect to the post on the main board. This is a technique demonstrated by Will Neptune at last fall SPFM meeting. While it is probably laughable to professionals, I'm not, and it provided me a relatively fool proof route to a curved top. I was particularly smitten by the clever wood removal from the stave which saves more difficult wood removal from the finished top. Will is a master at applying geometrical principals to make woodworking easier, which appeals to me.
One could change "saw" for "plane" and it would be a hand tool preparation. I will be planing the top when the glue is dry. Will demonstrated a clever sanding device for these tops which I will post when I get there.
The wood is quartered red oak and I will be posting some for sale soon.
making a curved top
Re: On making a curved top from staves *LINK*
Ron In Sterling CT
>Well it looks like all your research is paying off. I can't wait to see the finished top.
Wiley Horne -- So. Calif.
>Bill,
That was brilliant, doing the clamping jig upside down. But the exact workings of the jig are kinda mysterious to these eyes. So I have a couple of questions.....One, did you do the whole glue-up in one go? Two, it looks like the whole top assembly of boards, when pressure was applied, just snapped into position against the side contours of the jig. Is that right? Or did you do some fine tuning to close up all the gaps?
Wiley
answers
Bill Tindall, E.TN
>You said...."That was brilliant, doing the clamping jig upside down. " Well It was brilliant on the part of Will Neptune.
"One, did you do the whole glue-up in one go?"" Yes, you are looking at it just after I tightened the clamps.
Two, it looks like the whole top assembly of boards, when pressure was applied, just snapped into position against the side contours of the jig. Yup, it was amazing! However the forces distribute, the staves forced against the jig into perfect alignment. I had a large hammer at the ready but didn't need to pound anything into place. I never did such a cooperative glue up.
I am scraping it round now and at most I need to take less than 1/32" off to get it smooth. Hollowing the inside of the staves before assembly has saved a lot of scraping. The jig holds the top nicely while scraping the inside arc.
Hank Knight
>That's really neat, Bill. It looks like it saves a lot of work over coopering a panel with hand planes. Thanks for posting.
Hank
