Here is the OWT I made.
>Thanks to all who responded to my request for pictures of their OWTs... Old Woman's Tooth (or Old Hag's Tooth). This is what I came up with.
I had a amsll piece of Sepature left over from a cabinet I have just constructed. This is a Malaysian timber that looks very similar to Tasmanian Blackwood. It has stunning chatoyance and has a striking appearance.
The OWT is about the same size as the small LN and LV router planes. In this case it is 6 1/2" long and 3" wide. The blade is ground out of a hex key and has a cutting width of 1/8" (I wanted something small for inlays. I small be making a few more even smaller than this).
The blade is held in with a brass and steel knurled screw (one of my converted hose fittings!).
The underside and blade:
And compared with the LV and LV small router planes:
It feels solid and works well.
Re: Here is the OWT I made.
#2Where'd you score the knob ?
steve mackay
#3Re: Where'd you score the knob ? *LINK*
>Hi Steve
I made the knob.
Have a look at the link below - its an article I wrote about making knobs and lever caps without specialist tools.
#4I'll be darned . . .
steve mackay
>You make that look do-able ! Been think'n through a lever cap to convert a mutt bench plane and shopping the lever cap but can't bring myself to pony up the $ 80.00. Now, I'm think'n I just need to score a piece of brass junk. Thanks for the food-for-thought !
#5For smaller tools like spokeshaves
>you can also use various lamp parts, which (at least in the U.S. - don't know what's common in other countries) can be tapped from 8-32 to 10-24, possibly larger. I've used them on several metal spokeshaves and even my wooden mortise hinge plane.
#6Looks real nice Derek,
Scott Burr in Ben Lomond, CA
>Does the knob push the blade forward into the wood to hold it in place?
Is there a threaded insert in the body of the plane that the knob screws into?
Nice job!
#7Re: Looks real nice Derek,
>Hi Scott
The blade is held by the bolt pushing forward, like the LN and Stanley small routers, rather than by an eye bolt pulling back, like the ECE. The "problem" with the latter design is that it requires a thicker section to house the eye bolt. I was tempted to tap a thread into the wood but decided to use a metal insert for the most reliable durability.
#8I thought so. Thanks!
#9Re: Here is the OWT I made.
paul womack
>The biggest problem with hex keys (AKA Allen keys) as blades is lack of relief.
One could either do enough grinding to generate relief (optionally making the blade short to avoid making it too thin), or lean the blade forward in the holder.
Did you do either/both of these Derek?
BugBear
#10Re: Here is the OWT I made.
>Hi BB
I ground about 7 degrees of relief. The steel feels strong, but to be on the safe side I made this 1/8" blade a little shorter than the 1/4" LV.
