Brad awl and birdcage awl
>Is there any advantage in shop use to having a brad awl and/or a birdcage awl over other methods of making screw holes?
Birdcage awl is my choice
>Hi Bill
I prefer a birdcage awl for starting screw holes. It is more "powerful" than a scratch awl (which is just pointy and designed to scratch lines with the grain) and more controlled than a brad awl (which has a small blade, is harder to centre, and tears the wood).
I have a couple I made for myself that I use frequently. Usually I grab for a traditional, fixed version with a bulbous handle. This picture was taken when it was a scratch awl - never happy with it this way for starting holes. The pointy bit was good for marking a spot, but it had no penetrative power. So I ground it to a birdcage.
Recently I made a combination screwdriver, and one of the bits that snaps in (it is not magnetic) is a birdcage awl. I just see this as an integral member of the "team".
And with one of the screwdriver bits ...
Re: Screwdriver
Moses Yoder
>Is the combination screwdriver made using a kit? I would be interested in making something similar. (Not quite ready to buy the nice screwdrivers from LV)
Re: Brad awl and birdcage awl
>Bill,
The main advantage besides speed is that no wood is removed for making the 'holes' for nails or screws. So when the fastener is put into the hole the fibers of the wood can swell back and hold the screw or nail better than a drilled hole.
The real advantage (aside from keeping the wood from splitting) is the speed with which a hole can be worried into the wood. It is so much faster to grab a brad awl and make a hole than it is to get the right size bit, put it in the brace then drilling the hole.
I use them almost everyday and have a group of different sizes.
Stephen
Re: Screwdriver
>Hi Moses
Not a kit. I made it using a snap on connector from a drill accessory.
Brad awl connoisseurship
Adam Cherubini
>There's a subtle difference between the round pointy awls and those Stephen is showing us. Notice the lack of a taper and the blade end on Stephen's examples.
I find the tapered awls okay for tiny hardware. And though I have awls for this, I just use my striking knife as the hole is often more mark than hole. Awls like this just compress the wood and it can be difficult to make a deep hole, depending on the species.
I think the flat bladed straight-ish shanked versions that Stephen has are superior for fasteners that really need a hole.
I don't have a bird cage awl, but they look more like reamers than borers. I wonder if they were used to ream a through hole to a specific size rather than bore a pilot for a screw. I think brad awls are nice to have. I have some that match the tremont nails I use, which is extra nice.
The other nice thing about all of these tools s that they they take up no space so they are easy to keep handy and they can be used one handed.
Adam
