Tips on sharpening tiny router plane blade?
wilbur
>I recently picked up a Record 722 router plane. I'm having problems figuring out a good way to sharpen the bevel side of the blade, since it's so small, and the main shaft of the blade gets in the way. I've been using my bench stones, but due to the small size I'm having difficulty maintaining the bevel, and I wind up scraping the skin off my fingertips on my bench stones.
I thought about putting a little hollow grind on the bevel with a Dremel (first I'll have to buy one), but it doesn't solve the problem of holding the blade for sharpening.
Any tips on how to hold the thing so I can work on the bevel?
Re: Tips on sharpening tiny router plane blade?
Brent Smith
>Hi Wibur,
I just double stick tape a small block of wood to the back of the blade and go ahead sharpening.
MikeW
>Hi Wilbur,
I doubt my experience helps in any way...so I apologize in advance.
I just hang the shafts of the smaller routers off the side of the stone, press down on the back with a single finger while holding the shaft with the others. All done with one hand. At least for maintanance.
For fixing the blades as I have received them--they all have seemed to be in really bad shape--I use the side of a grinding wheel, very light pressure, to straighten them out.
I also don't hone to a high grit. Pretty much unnecessary to me. Of course, it's been a while since this boy has actually done woodworking. At the time it was Shapton stones and most likely it was the 2k stone that lived on my bench that was the highest grit I honed with to keep a decent edge.
Take care, Mike
Check this *LINK*
Denis Ch�nard, Orl�ans, Ont.
>Look for the instructions link at the bottom of the page (can't attach a direct reference, sorry).
DC
Veritas small router plane page
paul womack
Ah - the #722, a link from my site!
Here's another, on sharpening
Now, my jig is kinda fancy, but the prototype was made by just clamping laths together, and there were no wheels - just a horizontal lath running on the bench.
Give it a try - you just need mixed scrap + a few clamps.
BugBear
wilbur
>Simplest is best, and of course I was being to dense to think of it. Thanks!
Re: Check this
wilbur
>Hi Denis,
I saw that, but didn't know where to get the invisible blade holder and sharpening jig illustrated in this diagram. :@)
Patrick Gibbons, Somewhere in Texas
>I find it much easier to bring the stone to the blade. I use small hand-sized stones or those diamond paddles that are available and clamp the router blade in my vise. Actually, I don't clamp the blade come to think of it. I just hold it on top of a board with the edge overhanging the board so there is some room and run the stone over the blade. I have the small Stanley and find it very useful.
Hard to explain, without pictures, but I'll try
James Watriss
>As it was taught to me... it's intricate, so print this out to bring to the shop with you. Some of this will only make sense when you're at the bench working on this tool.
Step one: make 2 parallel cauls that sit proud of the sharpening stone, that are close enough for the sole of the plane to sit on. If the stone is too wide, lay down two wooden strips of equal thickness. The idea is to give sole a pair of surfaces that will allow it to slide in a motion that is parallel to the face of the stone. Trust me, this is actually important.
Step 2: place the plane on the cauls (or strips, if you used those), with a piece of paper underneath one side of the plane. Drop the blade to the stone, lock it into place, and remove the strip of paper. Run the plane back and forth until the stone stops taking away metal.
What this does is to tell you if the edge of the blade is, in fact, parallel to the sole of the router plane. It's very likely that it's not. What you'll get is a ground down area behind the edge. if this area is perfectly rectangular, and comes back an equal amount from the edge, then the edge is parallel to the sole.
If the ground down area is triangular, then the edge is not cutting parallel to the sole of the plane. What this means is that the plane will remove material, but you'll have a hell of a time trying to make a smooth surface with it because one side of the blade is hitting before the other one, and the point on that side will dig in.
Unfortunately, there's no simple way to build a lateral adjustment into the plane. You can't bring it back into adjustment. On the other hand, you can be assured that once you tune the blade to work with the plane, that it will ALWAYS be in adjustment.
Assuming that you're left with a ground down area that isn't parallel to the blade, you do need to make sure that it does go completely across the blade. If it doesn't, replace the piece of paper, drop the blade again, reset, and regrind. All you need is full-width surface, but don't go too crazy. If you get a triangle, that's good. You're going to grind it all away, so minimal area is better.
Step 3: Once the ground area goes all the way across the blade, it's time to hollow grind the bevel. Here's the truth: if you're left with an uneven area, you're going to have to do one of two things: completely regrind the flat of the blade, to make the necessary adjustment, OR hollow grind the bevel, and live with the fact that you'll get a skewed angle.
If you opt for the first choice, and you really want to restore the flat side, you're on your own. That's a lot of work, and you may be chasing it for days.
Because the ground area IS parallel to the stone, you need to grind all of it away. You may take my word for it (becuase I've done this a few times) that the rest of this procedure will work. Take the blade to a belt grinder or a dremel tool, to do your hollow grinding.
There are two edges to the ground area. Edge A is at the edge of the blade. Edge B is the dividing line between the ground area, and the rest of the flat of the blade. Edge B may be crooked, but because of the geometry of the stone set-up, you know that this is the angle that will allow you to cut a smooth bottom in your work. If you don't see it, trust me. Or, think of it this way. This is the angle that a smooth bottom defined on your blade.
A belt grinder or a dremel tool will have small enough diameters to handle grinding the bevel of the blade. You're going to hollow grind the bevel. You can do this in one of two ways.
-Don't joint the edge. This is the first option. Hollow grind, until that ground surface that the sharpening stone made is gone.
-Joint the edge first. I generally recommend this, despite the fact that it seems counter-intuitive if you've never done it before. It means putting the edge directly into the stone, at 90 degrees. You'll do this, and grind away any metal that was touched by the sharpening stone, all the way back to the aforementioned edge B. I know it seems wasteful. What you'll get when you're done, if you've done it right, is a facet that is thicker on one side of the blade than the other. But this is the blade geometry that will allow you to cut a smooth surface with this plane. From here, you'll hollow grind the bevel, with the grind coming down to meet this new edge. It does mean you'll have to grind more on one side of the bevel than the other. Yes, it's normal. And yes, it's important.
Once the grinding is done, you'll get a bit that is slightly skewed, but one that will meet the stone evenly... which means it will cut a surface that is parallel to the sole of the plane.
With this hollow grind, you'll be able to sharpen as normal. My recommendation in the future is to hone the bevel as well as you can, and do future sharpening on the flat of the blade, since it's easier to access.
Yes, I know this is a huge procedure. If you have a belt grinder, you can start out by practicing on an old allen wrench. Find one that's small enough to fit into your plane (The small router planes have round holes, so it should go in fine, and lock down fine) and use the flat of the belt to grind a flat bottom on the bent part of the allen wrench. Then use the stone trick to figure out how to do your hollow grind, and go from there. With this technique, you'll be able to make a set of blades of varying sizes that can be made very, very small... very useful tools for things like inlays.
Or, if you really don't like all of the above, you can spring for a new LV or LN mini... I haven't checked mine, but I'm pretty sure the blades cut parallel to the sole.
Two methods
>Hi Wilbur
Method #1
Add a fine hollow grind with a Dremel (or sandpaper wrapped around a dowel).
Now it is an easy matter to run it across a waterstone. I do this sideways..
Note that freehanding and hollow grinds go hand-in-hand. Attempts to hone a flat bevel eventually cause it to become rounded. That will make life very difficult with a router plane blade.
Method #2
You will need to make a jig similar to this. Here I am using the Blum Sharpening Box (however the idea was mine so I feel OK in showing it)..
Once again I prefer a hollow grind as the foundation. In this version you can use a diamond stone or sandpaper glued to hardwood to hone the bevel.
Different approach -- Jett-Sett *LINK*
David Barnett - SW Florida
>For hard-to-hone tools (router blades, gravers, and so on) I just press a glob of warm Jett-Sett over my [router] blade, press the bevel against a 1/4" thick EZ-Lap diamond bench stone, wrapping considerable goop it underneath until it cools, then use this jig to hone the bevel. How anyone gets by without thermoplastic fixturing compounds I do not know. Of course, in the old days there was pitch.
Jett-Sett Basic
>Wilbur,
Apparently you didn't like my suggestion of breaking up one of your sharpening stones to make a small slip for this router blade. And come to think of it I don't use a stone to sharpen my router bits, and I have 4 router planes.
I use a very fine file. The edge does not need to be like a chisel or plane iron, it is a router plane, it is for leveling off the bottom of a joint, mortice, &c. It isn't going to be that smooth no matter how sharp your tools may be. (And I don't think there is any room for a ruler).
Stephen
wilbur
>Hi Stephen,
Well, the only thing I have to break up my sharpening stones is a hammer, and I am a bit nervous about winding up with many more slips than I need, if you get my drift. :@)
Oh, and I only use a ruler for measuring and drawing straight lines, so no worries there.
I do like the file idea. Thanks!
Re: It Works!
paul womack
>Here's a kind endorsement by Alf of my approach, or at least the results.
BugBear
Use the side of the stone, Wilbur.
Andrew F in Australia
>Traditionally, wilbur, these are sharpened by sitting the stone on its side and sharpening it this way.
I haven't read the other responses, but this is how it was historically done. Easy as.
Grinding is a bit more difficult. Once again, the side of the wheel was historically used, carefully. This is a problem now as wheels aren't designed for side-loading.
Cheers,
Andrew
Re: Use the side of the stone, Wilbur.
paul womack
I think people find it easy to do, and very difficult to do well.
The vast majority of s/h hand routers I've ever seen have massively rounded (often rounded left-right as well as up-down) bevels.
I should probably note that I have neither a bench grinder nor a belt sander (AKA round and flat powered abraders), so the jig I suggest is used for both grinding and honing. It's just a matter of grit size.
I should further add, that since I do more tool restoration than tool use, my techniques have a tendency to be more appropriate to tools needing renovation rather than day-to-day maintainance.
BugBear
