Trunk bottom question
Bill Tindall, E.TN
>How are trunk bottoms installed. Like a drawer bottom in a dado, but what about expansion. Leave it open on the back like a drawer?
I have a vision of a coopered curved top, rift oak. Toy chest. Any ideas for a secret compartment for a trunk?
Re: Trunk bottom question
Pam Niedermayer, Austin, TX
>I don't know about all trunk bottoms, have seen some antiques that had nailed bottoms, drawers, too; but I treat these pieces more or less as I do framed panels. Keep in mind that there will be less moisture invading a closed piece, thus less expansion from the interior face.
Pam
D. Tardiff
>This is for a trunk with a built-in till along one end, with one wall
being the end of the trunk, and the floor and other wall installed when
the trunk is installed. (hinged lid optional)
The inner wall can move up slightly, which then frees the till bottom
to slide into the center of the trunk. This permits access to a hidden
space underneath, formed by a false end of the trunk.
Alternatively, for one more subtle, there is a false bottom of the till
itself.
James Watriss
>I made a blanket chest where the wall came up, and a drawer slid out from underneath the till floor.
As for the floor of the chest, most of the ones I've seen are NOT built like drawers. The bottom drops in onto cleats mounted around the edges, which hold the bottom up. The floor will need to be big enough to hang on the cleats, but small enough to allow room for expansion.
With all respect, I don't really buy Pam's idea that the inside of the chest will experience less ambient moisture change. It's not a sealed environment, neither the lid nor the floor of the chest are likely to be air-tight. Air moves. Warmer, more humid air, will displace cooler, less humid air, as the seasons change. It happens. A table top that's been shellacked top and bottom will still move with the passing seasons, and I think the shellac is a lot less likely to let air pass than a few blankets, toys, or sweaters.
As for other ideas for hidden compartments... go with the old standbys. False bottoms, false tops, hidden drawers, and the like are pretty standard. Your best bet is to find a dimension somewhere that's not easily comparable by eye... like how far up the floor of the chest is from the frame the chest is sitting on. (unless it's a simple 6 board box, in which case, how far up the floor of the chest is from the floor.) Adding tills and the like will give you more details to mess with, and more nooks and crannies in which to hide things.
Moisture movement
Don't know what to say, James, except that empirical data says you're wrong. The interiors of antique chests are never finished. The interiors of better made furniture are never finished and have survived quite nicely from Richmond to DC to Boston to Cape Cod to Austin, none of those places are slouches when it comes to humidity swings.
Pam
Adam Cherubini
>The sort of steamer trunks my family has are just horribly built, nailed together and strapped with cheap metal and leather.
I think you should use your own judgement since a toy chest will see conditions that the steamer chests weren't designed for. In my house, kids hide in toy chests. I even had one guy fall asleep in one. (He didn't pass out, it was a wicker basket). Which reminds me, don't make the thing airtight if kids can access it. Especially now with the popularity (at least in my house) of the Chronicles of Narnia.
Here's my attempt at ASCI art,showing a x-section of my tool chest:
X
X
X
OX
OX
OX
OBBBBBBBBBBBBBBBBBBBBB - FLOOR
OC -CLEAT SCREWED TO MOLDING
X= the carcass side
O= the base molding
B = the floor
C = a cleat screwed to the molding.
I make the screw holes in the cleat a little over sized so that the weight of the case, transmitted through the carcass sides is reacted directly by the cleat. The base mold doesn't actually see any load.
Adam
thanks to all, glad I asked
Bill Tindall, E.TN
>I have learned a thing or two about trunks that I didn' t think of.
I especially like "Adam's Art"
roninkokomo
>Put in a false bottom, Reinforce with ledger strips around inside of carcase. Rout groove under ledger strip bottom. Slide real bottom in groove attached to one end piece of the trip which is obviously not glued, but acts as handle for the real bottom which slides out
Re: Moisture movement
James Watriss
>Not arguing that, just saying that your comment that "there will be less moisture invading a closed piece, thus less expansion from the interior face," sounded wrong to me, since the chest will likely not be 100% air tight. And, if the interior is unfinished, the wood will actually be more more exposed to those changes.
James,
in Boston, which gets huge temp and humidity swings.
>James, sometimes logic doesn't get us to the right answer, we just have to experiment. I lived in Boston 10 years, and Falmouth another 10, and had absolutely no problems with unfinished interiors and moisture movement (btw, I don't much like air conditioning, so household contents experienced the full humidity range).
Further, inspired by a conversation on rec.woodworking about finishing the interiors, in which several noted woodworkers said they considered a piece not well made if the interior were unfinished, I contacted the Kenos and asked about antiques. The response, as I expected having lived around piles of good furniture when growing up, was that none, not one, antique piece they'd come across had the interior finished.
Pam
KIDS IN TRUNKS!
Greg Betit - Vergennes VT
>I put a latching lock on a 6 board chest I made for my oldest daughter. One of my sons thought it would be an excellent "hide and seek" hiding spot. It was too good, everyone gave up on him, even though he was yelling up in her room for them to help him get out. An hour or so later my wife thought she heard a faint "help" and went looking for him. I don't even like thinking about how this could have turned out, or about how terrible a memory this is for him.
If you have a trunk with a latching lock, keep it full or better yet replace the lock.
greg
Re: KIDS IN TRUNKS!
Glenn Madsen, SF Bay Area
>Another idea is to make certain that they are vented. A stuck kid that can breathe is better off than one who can't.
Every blanket chest is a potential toy box. Or a hiding place.
