Yankee questions
Yankee questions
Yankee questions
Edward in Vancouver
>Picked up a Yankee #30 (stamped North Bros)and a few other items including a monster 3/4" wide mortise chisel in pretty rough shape but with about 7" of length left to it.
I noticed on the Yankee that it is not spring loaded. It's in fairly good shape, but don't know if the spring was taken out intentionally or if it was just like that. I do have some bits and pieces to cannibilize from including a plastic and aluminum English Stanley Handi-man push-drill. What is advisable?
Re: Yankee questions
Re: Yankee responses
>Some of the Yankee drivers were spring-loaded, some weren't. I just went out and looked, and my spring-loaded driver of that size is marked 130A. I believe the two-digit model designation may have been the unloaded driver.
The logic was that a driver without a spring would not spring out and damage trim, break windows, etc., if the locking collar happened to get turned accidentally as you went through a house - thus preferred, as I understand it, by trim carpenters. I've never had this experience, but I have had some close calls and moments of startlement.
The disadvantage is that you must use two hands, one on the collar behind the bit, one on the handle. But I find, for slotted screws, that this grip is advisable anyway, since the slotted drivers tend to work their way out of the slot. With a Phillips or square bit and a spring-loaded driver, you can put both hands on the handle and pump harder, particularly when driving vertically. When driving horizontally, I find I can put my torso behind the handle and get plenty of grunt with a two-handed grip (partly because, with my particular torso, there's lots to grunt with).
My first Yankee was a non-spring-loaded driver, and it served me just fine.
I have a bias for North Bros drivers, partly because I dislike Stanley's habit of gobbling up the competition over the years, partly because North Bros was located in Philadelphia, my wife's birth city. It's also nice to know, with a North Bros driver, that it's at least 60 years old and still running fine.
Edward in Vancouver
>Thanks, though it might be so. Driver runs sweet, got it for a buck because the handle was covered with layers of electrician's tape. Once removed, the handle was actually in decent shape.
Never had one
Todd Hughes
>The Yankee screwdrivers that have a spring in the handle have a "1" preface to the number such as a model 130, 131, 133 etc. those with out the 1 such as your no. 30 never had a spring. While I guess anything is possiable I don't think you can easly add a spring to one of these....
....A side note...Have heard more then a few times about ebay buyers trash mouthing sellers that had sold them a Yankee no. 30 [or other springless model] that was "defective" because it didn't have the spring....when in fact it never did and they didn't know what they were talking about.....Todd
Re: Never had one
Bob Demers
>Ah yes, the many pitfall of buying old tools on Ebay without really knowing what to expect...
Todd is right not all Yankee push screwdrivers had spring in them The models No 30, 30A (improved model 30), 31, 31A, and 35 never had any spring assist in them and were refered as 'Spiral ratchet screwdrivers'
While models No 130 (A), 131 (A), 135 are the same as the previously described 30s series screwdrivers with a spring added in the handle which causes the handle to come back automatically after each push and makes the tool a quick return. these are known as 'Quick return Spiral screwdriver in Yankee litterature.
See pic
Source: Yankee tool brochure Copyright 1931 North Bros Mfg Co
Bob
And the models 30s
Bob Demers
>The original ones from which the 130s series is based from with the addition of the spring to transform them intop 'Quick return'
Bob, struggling with the size limitations in posting pics. It would appear that past 80K you loose your post and have to restart from scratch...ahhhh :-)
What a complete Yankee screwdriver look like
Bob Demers
>Finally, here is a pic of what a truly complete specimen should look like:
The green box, the paper packet for the bits, the three bits and of course, the screwdriver itself :-)
This one is a later model No 135A, which was made by North Bros after Stanley purchased them.
Ahhh, Stanley, the Microsoft of its days, to be the tool box of the world! All 30s and 130s series would have come as such, with 3 flat head screw bits
Excuse the poor quality, I had to thru MS Paint to post it, don't ask...
Bob
Looks like a fine Yankee screwdriver to me....
Scott Burr in Ben Lomond, CA
>Yea, You had to play with it, but nice pic!
Yankee bits installation instructions
Bob Demers
>And here are the actual instructions printed on the paper packet for the bits...If you ever had to fight with it to remove a stuck bit, at least now you know how its suppose to work :-)
Bob, owner of a 130A with a bit stuck in it, and nothing seem to work so far..
Posting
>"It would appear that past 80K you loose your post and have to restart from scratch...ahhhh :-)"
I learned some time back to go to the document file where the pic is and right click (Windows machine - not sure what the Mac equivalent is) to select "properties," which tells me the picture size, before using it.
Bill, learning from experience, however slowly
