seal coat
seal coat
seal coat
les winter
>I like working with a 2 pound cut of shellac and I particularly like Seal Coat. Other than the number of coats it takes to build a finish, is there any advantage to the other dewaxed shellacs out there? Do I really need flakes? I prefer a flat finish on much of my work.
thanks
Les
Re: seal coat
Re: seal coat
Glenn Madsen, SF Bay Area
>Choice of color? Packaging? Wax content? Availability? Price? Shipping?
All of those can count.
I use Sealcoat, as well as others. Depends on what I have, and what I need. It's pretty good stuff. And nothing of which to be ashamed.
Re: seal coat
Re: seal coat
"RJ" Whelan
>The only serious problem I've ever had with prepared shellac is not knowing how long it's been on the shelf. The chemists may have come up with a way to extend shelf life but back in the days, before I went to "flake", if it was more than about 6-12 months old it wouldn't cure hard. The test was to put a drop of the finish on the lid and wait 24 hours - if you could dent the cured drop with your thumbnail it had exceeded it's shelf life. I did an experiment with some 3# I'd mixed from flake (from Paddy O'Dean - is he still around, BTW?). I stored a small amount in a glass jar and tested it at 6, 12 & 18 months - it failed the thumbnail test at 18 months.
So, FWIW, you might try the test on your brand .... rj
Re: seal coat
thanks, guys.
les winter
