What woodworking has done to me
wilbur
>My nurse practitioner at my clinic said to me earlier this week, "Hey -- you have a workshop. Can you make some doorstops for the clinic?"
We have some doors in the clinic that have security locks on them that require an ID card swipe to open them, but they really just get in the way during the course of the working day, and we typically prop them open with something or other until the clinic closes.
So I made some doorstops tonight. But did I get a scrap piece of 2x4 and cut triangles out of it? Noooooooo. I used a cutoff piece of 8/4 white oak.
Then I sawed out a rectangular block.
Then I hand planed the sides smooth and square.
Then I sawed the block diagonally, to make the triangles.
Then I took each half and rip sawed it in two.
Then I hand planed the sawn faces, and also eased the corners with a plane.
Then I finished the doorstops with Waterlox.
By the way, all of the sawing was done by hand.
On top of that, I was careful to orient the grain so that you could see a quartersawn side from the top. It is white oak, after all.
That's what getting into woodworking does to you.
Geez.
Re: What woodworking has done to me
Moses Yoder
Re: What , no pictures ;)
Moses Yoder
But they're really, really NICE doorstops !
steve mackay
Kevin French, Antrim, NH
>And 'Someday' another WW'r will be in there and say 'MAN those are some 'FINE' looking doorstops'.
Or some janitor will slop floor finish all over them.
What no inlays!?!
Scott Burr in Ben Lomond, CA
>Maybe you should add some Ebony pegs and fume them.8^)
Alright, if you insist. :@)
wilbur
>Here they are. Hope the rays show up well enough. It was tricky getting the right angle to get them to show in the picture.
Fancy doorstops
Mmmmm, Cheese Cake!
Jesper, Denmark
Re: But...........
Jesper, Denmark
>You will have a little smile and remember everytime you pass through those doors and do not have to swipe the plastic to get through
Digressing
>"We have some doors in the clinic that have security locks on them that require an ID card swipe to open them, but they really just get in the way..."
It's always amazing to me how often this occurs - whether for security reasons or fire safety reasons, architects make decisions about making things inaccessible that just...don't...work. I guess some of it is inevitable, but still - you'd think there would be more consultation with the workers who have to use the space. I'd like to think there would have been a way to get the security and the workability both.
Re: Digressing further...
Glenn Madsen, SF Bay Area
>Fire regulations are what they are.
In our church building, the autoclose doors are much the same way. So there is one fellow who, on Sunday mornings, puts out all the doorstops. And then, Sunday evening, picks them all back up again, and puts them away for the week. During the week, you have to open all the doors by hand.
Fire regulations.
Re: Did you use a Fibonacci Gauge for the proporti
wilbur
>I used a 1:6 ratio, because it looked good to me.
Although, since it was a hardwood, maybe I should have used a 1:8 ratio instead. :@)
See, this is something else that woodworking has done to me. Now I'm making woodworking geek jokes.
Re: Digressing
paul womack
As so often in design, some requirments actually directly conflict.
It's most unlikely that you'd ever get a security expert and a fire safety expert to agree.
The security guy wants everything tight as a drum, locked, keyed, monitored, interlocked, the fire guy wants everything openable without keys at all times (with spring closers to stop the fire).
Their suggestions are pretty much bound to conflict.
BugBear
