New Japanese Planes
New Japanese Planes
New Japanese Planes
Mark in Texas
>I have 3 new japanese planes, I've never owned a true Japanese plane before. I'm having a hard time understanding how to adjust the blade. The blade housing is very, very tight; when the blade is in all the way, it still lacks a few mm's of being able to take a shaving.
Am I supposed to do something else? Am I supposed to enlarge the housing with a file? Should I hammer the blade in harder? If I do that, I'm afraid I'll break the wooden body.
Any help or references would be appreciated.
Mark
Re: New Japanese Planes
Pam?
Dan Donaldson
>Pam should be able to give you some pointers. Hopefully she will weigh in.
Howard Pollack
>Hi- All new Japanese planes need adjustment. To get the blade to come through you have to adjust the bed upon which the blade sits. Presuming that the blade is installed properly (with the bevel down) cover the back of the blade (where it will rub the bed) with pencil led or something else that will rub off (i.e. lipstick, marking pen ink, machinist blue) and tap the blade into place. Then remove it. The bed should have areas that have the material you put on the back of the blade. Pare that off with a very sharp chisel or a scraper or a float and reinsert the blade. Take off just a tiny bit at a time. Do this over and over until the blade just makes it exit from the block (dai). Do not pare the top ledges that hold the blade to the bed. This should do the trick. Good luck.
Re: New Japanese Planes *LINK*
wilbur
>Harrelson Stanley has a DVD called "Kanna: The Japanese Hand Plane", which will tell you everything, and I mean everything that you need to know about setting up a Japanese plane. It's $60, but you get 3 hours of instruction, and it's well worth the cost.
What kind of planes did you get?
Japanese plane DVD
Brent Smith
>Hi Mark,
I agree with Wilbur, Harrelson's DVD is probably the best source of info out there. In the meantime though you can check here to get started.
http://www.japanwoodworker.com/newswire.asp?month=3/2004
Pam Niedermayer, Austin, TX
>What Howard and Wilbur said, with some minor mods. The slot the blade sits in could be considered a discontiguous box. To allow it to fit, it's easier if you consider one side of the box untouchable, the front side as Howard said. To start, I'd do Howard's pencil trick on the blade sides as well as back, so you can determine whether the sides, back, or both are hindering the blade, then very gently pare the graphite off the dai.
If you'll use it without subblade, the abutment fit has to be tighter than if you rely on subblade for final fitting.
Be careful, get Harrelson's dvd, have fun. My solution for not knowing how to adjust these planes was to take a dai making class, which was very successful. One of the primary dai makers, Inomoto-san, will be in Berkeley in mid June, check out the Hida site.
Pam
Mark in Texas
>Thanks, everyone. That was helpful. Mark
What kind of planes did you get? Any pictures?
wilbur
Wiley Horne -- So. Calif.
>Hi Mark,
Arriving late, but here's a couple of thoughts. Let me pick up with what Pam said. Especially, get Harrelson's DVD. I would emphasize what Pam said about marking the sides of the blade. I've never seen a new Japanese dai/blade combination, where there was enough lateral movement provided by the daimaker. He leaves that to you. Usually, the blade is tight up against the side walls of the abutments (those two slots that hold the blade). In the event your blade is held tightly at the sides so that you have zero lateral adjust, it will take a 1/8" paring chisel, or else a 1/8" thickness plane float to pare back the abutment sidewalls just a bit. 3/16" is a little too fat, in my experience. Cut back no more than 1/32" on each side, and no further than half-way or two-thirds of the way down the abutments--do NOT cut all the way down to the bottom of the throat. Also, if you need to create this lateral play, do as Pam and Howard said and don't cut any material off the top (roof) of the channel. Leave the top of the channel as is, as you received it. The bottom of the channel may require some scraping to get the fit, but the pencil will tell you about that.
One other thing, and this is very typical of blade fitting....As a newcomer, you will probably fit the blade a little too tight. This is what most folks do initially, because intuitively you figure the worse thing is not to have the blade held tight enough. Here's a rule of thumb: If you are mushrooming the top of the blade, that is too tight--do some more spotting and scraping. By the way, note that the dai's bedding is kinda convex toward you--don't flatten it, it's supposed to be that way, to match the curvature of the blade. Trust your pencil marks. What happens if you overdo it, and make it too loose? You're still OK--you then glue a piece of all-cotton bond paper to the dai bed. Each thickness is about 4 thou.
IMPORTANT: Now, what if despite all your efforts, you get the blade in there a little overtight? Notice that there is not much wood below the blade, because the Japanese dai is typically bedded at a low angle, like around 40-42 degrees. What's gonna happen if the blade is tight? Well, the dai will deflect under the hammered-in blade, and a little bump will pop out on the sole, right behind the mouth of the plane. You can't see this bump, but it will wreak havoc with the plane operation. The plane will cut on first one side, then the other side, but rarely in the middle. All kinds of erratic behavior. You extend the blade, and it digs in; you retract the blade and it won't cut except at the edges. It'll make you crazy. The source of the problem is that the blade is too tight, but that is a subtle thing to understand if you're trying to pick up these skills by yourself. If you're getting erratic cutting behavior that you can't figure out, what you can try to get the plane working is to scrape off a couple or three thousandths, right behind the mouth opening. Do it with a scraper plane, going crosswise parallel to the mouth. Put the plane upside down in a vise, where the vise is grasping the blade (only), not the wooden sides of the dai. Just make a couple passes behind the blade opening, from side to side to create some relief behind the mouth. See if that helps things. It won't hurt. The thing to understand about a Japanese smoother is that there are two lines of contact--at the leading edge and at the front of the mouth. The rest of the sole is relieved by a couple of thousandths. So the last thing that touches the work as you make a planing pass is the blade.
This is just calling out typical stuff that goes wrong--it doesn't even begin to tell you everything to do. Get Harrelson's DVD.
Wiley
