REAL MILK PAINT
Finally, A Millers Falls 2B!
Stephen Kirk in Quakertown, PA
>I hit a very crowded flea market yesterday and amidst much wandering around only found one good tool. A Millers Falls 2B Eggbeater in really good shape. I had wanted to add one of these (after seeing some of Chris Schwarze's writings on them. Just gave it a quick try and it's a nice little drill. I can see how it will come in handy in a lot of situations. Quick bores for some screws, drawboring, or anywhere else I just need a few quick holes and don't have the need for a full brace (and swing room) or I don't want to get any electrons excited.
I am amazed at how well machined these tools are. I had heard they were well made, but until you crank one you don't really know. I mean, they are really good.
I just need to do a little cleaning on the gears. It works just fine, but could work better. An old toothbrush should take care of that in a few minutes.
Re: Finally, A Millers Falls 2B!
Hit the oil holes, too
>Light oiling of an eggbeater drill makes an astonishing difference to its operation. The No. 2 drill has long bearing surfaces, a good thing for stability of the bit, but, if not oiled, you can get considerable drag.
Moses Yoder
Re: Finally, A Millers Falls 2B! *LINK*
Moses Yoder
>Is there something special about the 2B, or are you just talking about eggbeaters in general? I prefer the 1530A over the 2B of course, but maybe I shouldn't mention it ;) And for those who are wondering what the 2B is as I was, check the link. I have a thing for eggbeaters I guess, but I just checked and there are none stacked beside my driveway so I think I'm still on the minus side of overboard.
Millers Falls Drills
>I first learned about them from this post on Chris's Woodworking Blog. I had never really paid attention to eggbeaters, but after this I thought I should give them a look. I don't know much about other types (yet), I was just happy to find one in pretty good shape. I usually see a lot of really junky ones.
http://www.woodworking-magazine.com/blog/CategoryView,category,Boring.aspx
Marv....... Northern California Lake Co.
>Hi Stephen,
The Millers Falls No.2 and the No.2B have two basic differences, the No.2 has a castiron main frame, the No.2B has an alloy or diecast mainframe. The very early No.2,s had only one pinion gear.
The M-F No.2 and No.5 were their most popular eggbeater drills. The No.5 is a little smaller but has a unique drive gear. It's much thicker. It's thicker to allow a finer touch when turning the gear with only your fingers without using the crank handle when drilling with a very small drill that requires some finesse.
If you want to see the best breast drill that Millers Falls made, take a look at the link below. The gears are massive. It has a quick removable huge breast plate and lots of other neat features. This is, in my opinion, the Mother of all breast drills.
Stanley tried their hand at making these drills but didn't come close to the quality of the Millers Falls or the Yankee North Bros. before Stanley bought out Yankee. Goodell Pratt also made some very fine drills of all sizes.
If you do some googling, you'll find lots of good history on the Millers Falls company.
Marv
Millers Falls No.97 Mother of all Breast drills
Oil or bacon. Hmm...
Scott Burr in Ben Lomond, CA
>Let's not go there.8^)
Bacon wrapped drills ... mmmmmmm
Eggbeater comparison
>I have used a Yankee North 1530A for many years (closest to the camera). This has a right- and left-hand ratchet and double-right-hand movement. More recently I added the Millers Falls duo.
The middle eggbeater is the Millers Falls #5, and the far one is the Millers Fallers #2.
As noted earlier, The wide rim on the #5's large gear can be grasped between the thumb and fingers when delicate work is being done. The #2 has the flanged roller which MF referred to as the "adjustable friction roll to equalize bearings".
This picture will give you some idea of relative size. The Yankee is 11" long tip-to-tip.
