glue question
glue question
glue question
les winter
>I'm building a drawer for night stand. Half-blind dovetails in the front and through dovetails in the back. So I applied the glue and started assembly. Arrgghh!. The back was miscut and is too long. I knocked the thing apart. Lucky I was using Titebond White glue. Nothing broke. I wiped away the glue that I could. I will cut one side of the back down recut the tails, and assemble it again, only this time I will do a dry run first..
I think that if I scrape the dried glue I will ruin all the joints, particularly in the half-blind front.
Does any glue stick to white glue?
thanks
Les
Re: glue question
Re: glue question
Marv....... Northern California Lake Co.
>You might experiment with epoxy...
Marv
Re: glue question
Sis says no....
John in New Mexico
>She's one of them art conservators, seems to know a lot about glue. Steam should help you get the dried white glue off, sounds like this is a recent mishap - thats good, glue still softish for a while. If that doesn't work, I'd try epoxy like Marv suggested.
Re: glue question
Re: glue question
Pam Niedermayer, Austin, TX
>You may want to try some discrete pegging if the glue proves a problem.
Pam
Re: glue question
Re: glue question
Dan Donaldson
>Take a look in the articles section. Bob Smalser did some testing of different glue to glue holding.
Re: glue question
hide glue
Warren in Lancaster, PA
>You can tell people over and over that hide glue makes the difference in ease of repair, and they act like nothing they make is ever going to be repaired. If you had used hide glue, the joints could have been cleaned off with hot water and reglued with little trouble.
You might try using vinegar to soften your glue or you might try paring the stuff off with a sharp chisel to the point where the pieces go together easily. I think that you could reglue with your same glue, although it will not be as good a bond as with fresh wood. A dovetail joint is partly mechanical and does not need the glue strength of an edge joint. I would use hot hide glue.
Re: glue question
Re: hide glue
ThomD
>I don't know of anything that will stick to white glue, and I buy epoxy by the barrel at times. Anoyingly you probably queered the white glue's fully sinking in to serve as a good base for any re-gluing. If I had to try something it might be a vinyl cement, but that is more a chemistry answer (non-chemist here), than something I would actually try. Cleaning would be my approach. Call Elmers and see if there is a magic cleaning bullet.
Re: glue question
Re: hide glue
John in New Mexico
>I forgot to say that as far as I know, hide glue is the only glue that will stick to itself once fully cured. I like Pam's pin suggestion though. How about inventing the wedged pin dovetail joint? Or even the fox wedged dovetail? Not just for handplanes anymore!
Re: glue question
Re: hide glue
les winter
>Thanks everyone.
First off, I don't know why I didn't use hide glue; I just bought a fresh pint.
So I recut the joint and used white glue again this morning. I let it set for 8 hours. I just got finished planing the sides, and all seems well. I'd rather be lucky than good. Today was my day.
thanks again.
Les
Re: glue question
more news
les winter
>I called Franklin, who makes the white Titebond I used. They advise that after the white glue dries, it will get softened by a new application of their white glue. They said that the drying time will be greatly extended, but the glue will bond. Not so with Titebond 2 or 3 which are water-resistant/proof.
Have a good week.
Les
Re: glue question
Re: more news
ThomD
>Very interesting. I have just slathered the stuff on heavier when it starts to go before I have an assembly done. I didn't know that it would re-tooth when fully dry.
"I forgot to say that as far as I know, hide glue is the only glue that will stick to itself once fully cured."
Actually that is one thing that epoxy does, and possibly crazy glue also. One can get pretty deeply into discusions of bonding versus adhering, and secondary and primary bonds, but as long as one says "stick to itself" , it's a pretty safe statement. A lot of composites are molded into a big piece, like the hull of a boat or plane, and then subsequently more parts are attached using more of the molding resin, normally an epoxy in higher end construction. Hide glue is still pretty unique in how co-operative it is. It re-boads with heat or new glue over old, etc...
Re: glue question
Foxed wedged dovetails?
>Don't think you can do these, John, give the way dovetails are assembled.
Pam
Re: glue question
Well, more of a joke than real...
John in New Mexico
>But I could see a sort of double tapered dovetail socket with wedges pressed in while seating the tails. The joke is more in being far, far more trouble than I would expect anyone to go to when they could just use some glue or pins ;)
Re: glue question
Makes my head hurt. :)
