Veritas - Innovation in Tools
Shaded fan inlay, and flipping sharp plane blades
wilbur
>Here's the shaded fan inlay I learned how to make from Mario Rodriguez last weekend. Our woodworking club arranged to have a class with him.
Shaded fan inlay
The inlay isn't completely done -- there's a banding that is supposed to go around the perimeter, and the circular part needs to be trimmed a bit more. But given that I didn't lay out the shaded fan parts in the best manner (they should have gone more from dark to light), I probably won't complete this one. But it was fun learning how to do the hot sand scorching technique, and learning to work with veneers. I had never worked with veneer before.
The best thing that I got from the class was some validation that I am doing a good job sharpening my plane blades. Mario was showing our table how to tweak the sides of the fan parts with a block plane and borrowed mine to demonstrate. He took a few swipes, paused, and said, "Boy, that's a sharp blade in this plane!"
Yay for me!
Today I had another validation of my plane blade sharpening technique. Apparently I have a bad habit of lightly rubbing the pad of my index finger over the mouth of the plane to check the blade position. I think I do this so often that I'm not real aware of doing it. I found this out later when I became aware of the cuts in the pad of my index finger while eating some potato chips. I became aware of this the hard way. Put it this way: the bag says "Lightly Salted", but it felt like they put a few pounds of salt on the potato chips.
Boo for me!
Re: Shaded fan inlay, and flipping sharp plane blades
barryvabeach
>Great looking inlays- I think the shading looks good. Barry
Wiley Horne -- So. Calif.
>Wilbur,
That's beautiful!! Shading looks perfect to these eyes. As you worked, did you feel 200 years older? Are you going to work those into the corners of a desktop or cabinet doors?
Good feedback on sharp. Have you gone through different sharpening methods, and what are you using now? Also, do you use a test to check a freshly sharpened blade, or do you just go through a sharpening procedure that you just 'know' works?
Wiley
Brent in Montreal
>That's a nice looking fan Wilbur and that compliment from MR says a lot about your sharpening talents. Save your finger prints and use a small piece of wood to check for blade projection from now on :).
wilbur
>As Mario was going through the explanation as to how to use the hot sand to do the shading, and what factors you needed to keep in mind, like how close to the center of the hot plate and how deep you put the piece into the sand, it hit me that this was really just like working a barbecue grill. So I didn't really feel older -- I felt like I was cooking burgers and steaks. :@)
My sharpening technique is pretty basic: Shapton waterstones - 1000, 5000, and 8000 grit. No microbevels, and I sharpen freehand. The first sharpening method I learned was Scary Sharp, but I didn't like the mess, and I always thought that the sandpaper was rounding over the edge. I also have a coarse diamond stone for dealing with big nicks, and although I have a Tormek for use with turning tools, I use it to establish or change the bevel angle on plane blades and chisels initially.
I've made my first step into using natural Japanese waterstones after picking up one of the Lee Valley closeout waterstones a little while ago. This stone is considerably softer than the Shaptons, but it puts a finer edge on the tool than the 8000 does. I haven't had a chance to try a super hard Japanese waterstones yet.
What I would have done different
wilbur
>Forgot to put this in my reply above:
Thanks for the all the compliments on the shading, but if I were to do this again, I would have arranged the fan pieces differently. If you number the fan pieces 1 to 8 from left to right, I would have arranged them 1, 2, 3, 4, 8, 7, 5, 6, so that the pattern of the shading progresses from light to dark a little better.
I see what you mean...
Scott Burr in Ben Lomond, CA
>But still Wilber, it looks good to me. Sounds like a fun class to attend.
You can't beat a complement like the one you received. I'd feel proud.
