New Veritas lapping plate?
David Barnett - SW Florida
>Why such deep and wide swarf channels? I'd think my narrower chisels would take a beatin'. Forget the gravers.
And what was wrong with the plain ol' grid? Does it need to to look like an Italian street map to lap in figure-eights?
Is the reverse side ground, as well?
Re: New Veritas lapping plate?
Rob Lee
>Hi David -
You get my last reply for awhile.... :)
1) grooves are milled, not cast, and have a minimum width. What's difficult to see in the pictures, is that the grooves are also chamfered - so the edges won't get sharp and take off your fingertips...
2) depth is just fine...
3) groove shapes are a fuction of studies to make for smooth lapping in any orientation... you don't want straight lines!
As they say across the pond.... it works a treat!
Cheers -
Rob
comments
Bill Tindall, E.TN
>I haven't seen the plate in person and I am not certain for what purpose it is designed. But for sharpening with diamonds I have seen no need for deep grooves. The amount of abrasive used and the amount of metal removed does not require groves in my experience. When we prepared cast iron plates for sharpening a variety of surface preparations were tried, driven by expense more than an investigation of what was best.
The cheapest surface resulted from Blanchard grinding which left swirl marks ( like table saw tops). We also had some plates surface ground and they were quite smooth. I didn't see much difference between them. I like the fact that bevels suck down on the plate as it aids keeping the bevel flat on the plate while sharpening.
Re: comments
ThomD
>It's not designed for diamonds, as I'm sure you know, Bill. It might have been fun if the non-swirly side were designed for diamonds though.
From LV website *LINK*
Wiley Horne -- So. Calif.
>Silicon carbide. See link. Why not a diamond paste version?
Wiley
LV lapping plate
Re: From LV website
ThomD
>They have been selling this kind of stuff for 30 years. The bottles of SC, the Kanaban, now this version. The great advantage to SC is that is keeps breaking down into finer particles. It perfectly flattens and mirror shines the back of a chisel, or whatever. It takes a long time, and is pretty messy, but it does work. Diamonds are forever, which is a big advantage but a different approach.
I meant to park my post under
>Bill Tindall's 'bewildered' post, but got discombooborated (sp?). One thing I really like about LV's approach here, is that they put a flatness spec on the plate. I've never seen a flatness spec for the Kanaban plate.
If LV would forego the pattern, and resaw that iron plate into three flat 5/16" plates, it'd be a great diamond paste substrate.
Wiley
Paul Kierstead
>I tested the plate in a slightly pre-production version (no chamfers, it was a good idea to add them and I suggested it, but they actually beat me to it anyway). I didn't pay for it, but I don't use and hate lots of gear I did pay for, so I don't know that it sways me much either way; mind you, I am predisposed to like a local supplier/manufacturer anyway. I used 280 and 400 grit and did a couple of planes (a 4 and a 4.5, both concave), a couple of wide chisels (all concave) and a couple of blades (mostly wrecked). I found it worked quite well and it will earn a permanent spot in my arsenal. I was actually kind of surprised how well it worked on the planes. The instructions are well worth reading and contemplating; in particular, the achieved finish is not high gloss or anything, so it isn't start to finish for most things, but what is?
BTW, it is bloody heavy. You just don't expect something that size to be that heavy. Still can move though, especially when your lapping a plane.
