A55 Smoothing Plane
Locating screw holes ( like for hinges)
Bill Tindall, E.TN
>Were it not for the invention of the Vix bit I may have abandoned woodworking long ago. I was never successful at getting a pilot screw hole reliably centered in a hinge hole. Some grain nonuniformity would always scoot the drill off center on one or more holes.
Centering holes in hinges, and the like, was obviously solved in days of old with out Vix bits. So how was it done? I got to thinking that maybe a cut nail would have worked for hole making, or something else not sharply pointed.
Re: Locating screw holes ( like for hinges)
Optical center punch *LINK*
David Barnett - SW Florida
>I'd hate to be without mine. Cheap and useful ones for woodworkers from Garrett Wade and LV. I have a Starrett.
The LV - Veritas version
Dale Lenz
Re: Correct me...
Dale Lenz
>if I'm wrong; you are still Guessing where the center of the hinge hole is(?).
A tip *LINK*
>If you DO punch or start to drill a bit off center point, you can use a 'bud bur' in a pin vise, flexshaft, mini-Archimedes drill (one handed with spring) -- even twiddle it with your fingers, pulling back (at an angle) to center point, and thereby 'move' the hole. This is a lifesaver when flush setting gems but has earned a place among my hardware tools, as well.
You can get these for less than buck at any cheapo jewelry supply.
A bud bur
Dean J in MN
>Trusty bradawl.
>I suspect that this was yet another part of the apprenticeship - that is, practice, practice, practice.
Depends...
>...what method of layout I use. Direct from hinge, might as well use a VIX, center punch or awl. My no-name offset punch has a concentric ring reticle, so it can really pinpoint and punch, accurately referencing through the hinge hole.
let me clarify- centering the drill hole
Bill Tindall, E.TN
>I don't have any problem locating the center by eye ball. Or even pricking the center with a punch. It is when I drill the pilot hole that the drill can scoot off-center if it hits a growth ring or other irregularity in wood density.
Ah! Don't know what folks used t' do...
>...but pipemakers who have to negotiate the nasty surprises of gnarly briar burls use bullet point pilot bits, on lathes, drill presses and by hand.
Push harder
>I find that if I push harder on the awl, so that I get a larger hole, the drill is more inclined to stay on course. Regular metal bits have a rather large "point" surface, and need to be nestled down into the wood some to track properly. I usually do this as a two-step: push enough to properly center the initial mark, then harder in that spot to get a hole. If I owned a bradawl or a birdcage awl (I'm considering getting LV's, though I'm not sure I need them), I might find that this second step was easier; but using my collection of scratch awls and ice picks has worked fine so far.
Skip in Falls Church
>Hi Bill,
I use an awl followed by a gimlet. I've found that since the process of drilling by hand goes slower it's easier to see if the hole is drifting off. The shaft of the gimlet gives a good idea of how straight it's drilling. I've also found that it's easier to correct if the hole is going off in one direction or the other.
Skip
Jim in Burlington Ont.
Self Centering bits
>I bought them at LV self centering bits. I don't drill very agressively to get best results.
But Bill Tindall's question was about how it used
>to be done. I doubt there were many 18th century self-centering spring-loaded drill bits.
"RJ" Whelan
>One of the tools I inherited from my grandfather was/is a self-centering punch. It looks very much like a modern tool of this type, but it isn't spring loaded. The name on the tool is Indergand, which is Swiss: he served his apprenticeship in Switzerland in the 1890's and the tool certainly looks over 100 years old. It still works great and there's still about 1/4" of useable tip on the punch part (certainly it will outlast me - I've had it for over 40 years and have only ground off about 1/8"). It's really a simple design: a 1/16" punch going through a 1/4" sleeve with the business end of the sleeve ground to a cone shape. FWIW .... rj
Dale Lenz
Dale Lenz
>I've though of a tool like that today in my wondering different way to center the "pilot" hole in hinges and other things. If you find a name on that tool please let us know.
Hinge center punch *LINK*
Wiley Horne -- So. Calif.
>Dale,
I have a hinge center punch very like this Lee Valley one, only I don't recall where mine came from, I've had it so long. Sounds like the same kinda tool RJ is talking about, except that these modern ones are spring loaded.
Works great--see link. As I recall, the VIX bits skip a step and locate the hole and drill it in one motion.
Wiley
Hinge center punch
Dale Lenz
Re: Thanks
Dale Lenz
ThomD
>I can't say what they did in the days of old, but an awl works fine so I don't know why they wouldn't have just used that. A metal pin (dowel in wood speak) with a point in the end like those dowel ceners might work if it was set up for a specific hinge style.
I use the dowel by leaning it's point off center so it rest on the hinge. I then move the point to the center and come off the hinge dead center. Of course when I check the hole it is occasionally off center, but since I make it light initially there is plenty of room to stear it back. In fact if it isn't much off center I may just drop the dril in there and stear it back. One doesn't need to be perfect as long as one can stear it back to center. And it all talkes a lot less time to do than write about.
paul womack
>Drill drift in non uniform materials is a problem; many of the responese here appear to be address the marking issue, which isn't THE issue (IMHO).
If I really need a hole in the right place, I cramp down a small piece of scrap mild steel I made ages ago. It has various size holes in it.
I clamp the appropriate size hole over where I want my final hole, and I (thus) have a low-grade drilling template, which does an adequate job of preventing drill drift.
BugBear
Marv....... Northern California Lake Co.
>One would think that making a drill, drill exactly where you want it to start a hole would be a simple thing to do. Most of the time it is, but sometimes it can mess things up pretty bad.
A hinge has to be placed in a certain location and that's where it needs to stay. Usually you can't move it around to avoid a hard coarse grain that will run across the countersunk hole in the hinge.
Here's what I do...with a sharp pencil I circle in each hole. The circle will be quite small in the smaller hinges. Then with the use of a sharp center punch that is a size that pretty much matches the size of the screw I'll be using, I merely tap it into the center of the penciled circle. The center punches I use are the type that a machinist would use and they come in sets from very small to about 3/16" at the pointed end. An awl might be used but I find that I can control a proper size center punch with great accuracy by leaning it to one side or the other as I tap it with a hammer and actually break that coarse grain. Once I know I am centered in the pencil circle I can then hammer the center punch straight down. If the circle is only about 1/8" dia. it is easy to get the center punch centered. At his point I have a tapered hole deep enough for a pilot hole to be drilled exactly where it needs to be. I drill all the holes without the hinge in place.
Sometimes you can clamp the hinge in place. In this case you don't need to use a pencil and circles. You can just center punch in the center of each countersunk hole in the hinge, using the same technique of leaning the center punch one way or the other to break through that tough hard grain. The secret is to just tap the center punch at first until you see that it is going to stay in the center, then tap it deeper, enough for the pilot drill to stay centered.
Marv
thanks
Bill Tindall, E.TN
>I can see that one problem was that I was marking the hole for the drill with a punch rather than making a pilot hole for the drill with the punch. One might also wonder if the drills used in days of old may have been fashioned to handle grain changes more successfully than the metal drills I use for hinge holes.
old drills versus todays
>Bill,
I have quite a collection of old eggbeater drills and push drills. Some of the old eggbeaters would have original drills stored in the handle. Some of those drills had straight flutes just like you see in a push drill such as the Yankee North Bros use. Comparing those old drills to a HSS metal cutting type drill with helical flutes, my choice is the present day drill for the purpose we are discussing here.
After posting to you about using center punches, it occured to me that a simple nail could be used for centering up in a hinge hole. In fact now that I think about it, I've done just that on occasion. Best to grind a point on it first though.
Marv
Sgian Dubh
>Bill, sometimes, with the hinge in place, I spin a countersink bit mounted in an electric drill into the screw hole. That does a pretty good job of getting you started in the right direction. Still, a bit of hard grain can cause the follow up drill-bit to go off line, but it's rare. Slainte.
Dave Anderson NH
>Hi Bill, I use a set of machinist's transfer punches which can be purchased in different sized sets from MSC, McMaster-Carr, and Lee Valley. MSC had them on sale in a flyer a couple of weeks ago. An import set of 16 or 18 for about $15. These are useful for all kinds of things other than just locating hinge screw holes. Go to one of the wesites for these folks and search for transfer punches.
