Chaplins 1255 plane
Chaplins 1255 plane
Chaplins 1255 plane
Wayne Carson
>25 years ago I got hold of a Chaplins 1255 plane and the front knob was broken. I need some deminsions so I can turn one and what kind of wood were they made of.
Re: Chaplins 1255 plane
Bob Demers
>Wow, that is a rare bird!. I cannot help with dimensions, not having one myself, but if I can, I'll try to post pic of the plane showing the knob. My pics are embedded in Word docs...
This is one mighty nice plane my friend, about the size of a No 4 but weigh more like an infill and has an adjustable mouth much like adj. block plane, one nifty plane.
The rear tote is not made of wood but rather some sort of hard rubber. It should sport the tell tale crosshatch marking on its side and a faint cast line on top. Altought not stated, I do believe that the front knob is indeed wood, but it could have been made of that hard rubber. Even dinged up they seems to remained black, so perhaps black ebony?
Bob
Bob Demers
>Chaplin 1255 plane, pic
Bob
Dale Stansbery
>Here's a couple pics of the front knob on my 1880's #4 size adjustable mouth, corrugated sole Chaplin when they had a nickel plated steel tote and the scalloped sides. The knob is 1.64 inch diameter at the top, .934 at the bottom (extends up .13 inch), 1.63 inch tall, .771 inch neck diameter, and the neck centerline is .384 inch from the base. The centerline of the top large diameter is at 1.273 inch from the base. I can't tell what the wood is, but it could be walnut. It's heavily painted black. Good luck on figuring out how to duplicate the brass nut press fit into the top.
If anyone has a correctly marked 1880's 2 inch blade, I may be interested. These old ones didn't have a lateral adjustment and the blades were solid plates, no holes.
wayne anderson
>The brass threaded insert on top would not be too hard to make if you have a lathe. Just drill/tap the appropriate diameter brass stock, and use straight knurling for the outside diameter. Counterbore the knob for the press-fit. -w
Todd Hughes
>Heres a photo of my Chaplins No. 233 ...A neat plane that is just a tad bigger then the stanley no. 2 seen behind it. Front knob ain't ebony but looks like maple painted black.
I wanted one of these for a while and finaly found this one, which is in excellent , really near mint condition [just some loss to the nickle on lever cap] at a flea market priced at $15 setting next to a rather beat Stanley no. 5 priced at $25. Managed to talk the seller down to $12 since it wasn't a Stanley and had a plastic handle....Todd
The Handle
>Todd,
You mentioned that the seller, sold it for less because it had a 'plastic' handle. If the model is from the 1880's it couldn't be Bakelite, so it must be gutta percha?
What do these planes sell for?
Stephen
Re: The Handle
Todd Hughes
>I think my plane probably dates from the early 1900s.
I think the handle is what is called "Hard Rubber" a material that dates back to the civil war at least as I once had a tiny black Berridan sharp shooters button made out of it.....Todd
Handle photo
Todd Hughes
>Heres a photo of the handle, is very hard to find these planes with handles this nice as the material they were made of tended to break, chip and warp pretty easy apparently. Have seen a few were the checkering were worn smooth too. Probably made thinking that they would hold up better then wood but I don't think they did....Todd
Re: Handle photo
>Mr. Goodyear's vulcanized rubber no doubt (pre Civil War, his process). Gutta percha would have been earlier.
Stephen.
Re: The Handle
Bob Demers
>Stephen
Well condition is everything, but considering Todd's plane condition, and the fact that he got it for a mere $12, I will say definitively qualifies as a gloat. Todd you sucks! :-)
Most of Chaplins planes are worth in the low hundreds, the 1255, being somewhat scarce, fetch easily $300, maybe more.
Bob
Re: Handle photo
Bob Demers
>Leonard Bailey early planes, pre Stanley/Bailey, also sport similar hard rubber tote (thats what's they are described as being made of) and also had some sort of cross hatching pattern on. I wonder if they came from the same source?
Those totes, and sometimes knob, didnt seems to have remained long, being quickly abandonned for all wood totes and knobs
Pic is from Bailey Victor No 4 pat Dec 12 1876
Bob
Insert
>Several times, I've removed similar nuts from furniture (did I save them? Who knows? Shop looks like it's been turned upside down and shaken). I wonder whether McMaster-Carr or one of the other online dealers might offer them, or something similar enough to work.
Not 1255 but 1277 per Peter McBride
Wayne Carson "TX"
>I sent peter McBride some pictures and found out that my plane is a 1277. Here is the link to his site lots of info.
http://www.petermcbride.com/chaplin/
Re: Insert
wayne anderson
>Typically, those threaded inserts have machine threads inside, and wood threads out. The insert in the photo appeared to have straight splines outside, which could be replicated with straight knurling. It may very well be the case that the proper type of insert is available off the shelf, but by the time you find one and order it, you could have made one. I have the material and equipment to make one in about 10 minutes, so that's what I would do. -Wayne
Re: Insert
Wayne Carson "TX"
>Lets see I know how to use a metal lathe. I have the brass to make the insert. All I need is a lathe and tooling. I guess I could drill and tap the brass and hand file the splines on.
Thanks for the dimensions
Wayne Carson "TX"
You're kidding, right?
>This plane, cleaned up, might be worth "in the low hundreds?" Or, given its condition, in the low tens?
How would I find out what model plane I've got here? Is there a Blood and Gore for Chaplin planes?
Re: You're kidding, right?
Bob Demers
>No Bill Im not kidding.
Matter of fact im a bit cautious in my low ball estimates.
But before you get too excited, realize that the right price is only what the right person is willing to pay at the right time in the right venue. Ebay is a crap shot at best, reputable dealers will of course pay you less than its worth, since they have to make a profit, etc.
But nonetheless, Chaplin's plane are very desirable from a collector point of view because they are not plentiful and they have a unique adjuster system, and a rather funky look :-)
As for ID or type study, check out Peter Mcbride site, that was included earlier in a previous post, link added again here
Bob
Re: You're kidding, right? *LINK*
Bob Demers
>grumble brumble
OK, third attempts at posting link...
Bob, who obviously need a coffee refill
Chaplin planes
