cheapest, easiest, fastest and good as any....
Bill Tindall, E.TN
>Let me begin by saying that if someone told me before I tried it that I could, and would prefer, to sharpen free hand I would have blown them off as yet another highly experienced woodworker underestimating the skills of mortals. There are all sorts of woodworking skills that I have been told are "easy", that are more like impossible in my hands. That said should make the following more credible. If one will try it success will follow or you are such a Klutz that working wood with hand tools will be impossible and this is all a moot point anyway.
Every element is important to make the overall process easy.
1. Buy a power grinder and the appropriate wheels and tool rest. All this part has been discussed below in detail the last few weeks.
2. Grind a hollow grind on the tool. Again this technique has been discussed recently.
3. At this point you are a minute from a sharp as you need too be edge. The secret to making the next part easy is the hollow grind. The next part can be done without a hollow grind, but not near as easy as a hollow grind. I can't ( and won't) do it with out a hollow grind.
4. Select any medium coarseness abrasive format. I used a fixed diamond fine stone but it could as easily be 1000 grit sand paper, water stone, etc. Grasp tool in both hands with thumbs under and index fingers pressing on the top right over the bevel. Lower tool to the stone and rock it back and forth pressing the hollow ground bevel against the stone sruface. Your will feel the hollow grind suck against the stone (presuming the stone is flat) when the plane of the bevel mates the plane of the stone. This is a critical thing to be able to feel. Practice it a bit, rocking tool back and forth till you can feel the engagement. Once you got it pull the tool slowly toward you across the stone. By pulling slow you will be able to feel that the bevel remains engaged with the stone surface. Now here is the beautiful part.***** You only need to make a few strokes across the surface to remove the grinder scratches because you are only abrading the first tiny bit of the tool's edge.**** And because you only need to pull a few times your patience will not wear out and you will be able to keep the bevel properly seated on the stone surface each stroke. As soon as you have uniform grind mark across the edge you are done. It could be as few as 5 strokes if the edge from the grinder is straight.
5. Repeat step 4 with the finest grit you want to use. I use 1 micron diamond, but a fine water stone or sandpaper would be fine for most tools. In about 5 strokes you are done.
The reward of cheap, and quick makes learning to sharpen this way worth a bit of practice and the small investment for a proper grinding wheel. I presume everyone has a grinder for other tasks around the farm.
