Siegley`s No.3 Wood Plane
Helen
>Hi,
I am not a carpenter or a tool man but have acquired a Siegley`s No. 3 Wood Plane. It has a circle of words on the top of the blade that reads as follows: Siegley`s Pat`d Dec 5 83 or 93. The 8 or 9 has a worn spot at the top and I cannot determine the correct number.
My question is, Was it patented in 1883 or 1893?
Thank You for any information you might provide.
Helen
Re: Siegley`s No.3 Wood Plane
Re: Siegley`s No.3 Wood Plane *LINK*
Bob Demers
>Helen
That would be 1893, and patent No 510,096
See link
Cheers
Bob, slowly shedding his snow tires
Siegly patent
I am curious about the purpose of
Wiley Horne -- So. Calif.
>the modified lever cap in the Siegley plane. It being adjustable up and down by set screws. Was the point to eliminate the cap iron, and let the lever do the chip-breaking?
Wiley
Re: I am curious about the purpose of
Warren in Lancaster, PA
>Yes, Wiley, the lever cap sits on set screws against the cross bar. You can adjust the cap iron distance from the edge with these screws. I think that if you were constantly using the plane at the same setting of iron and cap iron, it would save a little time.
Bob Demers
>Wiley
Good question. According to the text of the patent, it says Quote
The cap can be adjusted into higher or lower position, so that it is readily adjusted into its proper relative position to the plane, even as the cutting edge of the same is ground off by use Unquote.
I always used it to set the edge of the cap parallel to the cutter edge on mine, sort of instinctively before I read about it, just because thats what it seems to do. Being a single iron plane, I suppose its sort of serve as a chip breaker.
Bob, who owns a No 5 specimen
Helen
>Bob,
Thank you for the information. I do have one more question. The bottom of the plane is corrugated. What is the purpose of this in comparison to a smooth one?
Sorry to be such a dunder-head about tools.
Thnks,
Helen
Bob Demers
>Hi Helen
Don't be shy, being a newbee, we were all once :-)
Ask away, we are all here for that.
The plane sole corrugation was an attempt to solve an overblown non-issue (IMHO) with the metal sole of the plane developping some sort of suction problems with the wood. In my opinion, its more of a marketing gimmick than anything else. True, resinous woods may feel a tad more sticky (no pun intended) but before you really feel that suction problem, you really have to get that wood planed surface very flat...
Historically, I think it has more to do with trying to convince wood planes users to switch over the then new fangled metal planes. A wooden sole does not have the same feel as a metal sole when planing wood, some prefer one over the other.
Quite a few designs were patented to 'overcome this problem (?)'
The corrugated sole, like you have, being the one that became the most successful from a marketing standpoint, not in practicality.
That added machining step, of course came with a small premium, and today, Corrugated soles go for a higher prices on the collectors market. The other most often seen bright idea was to inlay strip of wood into the sole as in the Steers patent of Sep 11, 1883.
In addition there was also a new hybrid class of planes: the transitional. You had the advantage of the new fangled blade adjuster in a wood soled plane. Again, mostly to win over convert.
Personnaly, I had never really felt any advantages to the corrugated soles and prefer my soles flat. Waxing the soles, does a better job of solving that 'non-issue'. The only undisputable advantages of corrugated soles, is the fact that they are faster to lap flat :-D
Bob, the tool historian
Helen
>Bob,
I appreciate your response very much. It`s nice to know there are people out there with so much info.
Best Wishes to you.
Helen
A common question
>Helen,
This is a common question when folks first encounter older metal planes. I agree that there's no real functional improvement - in fact, in certain circumstances, the corrugations can cause the plane to "self-steer" irritatingly. This, though, is rare, and there's no harm in using a corrugated plane.
If you're getting started with hand tools, go to your local library and see if it has "The Hand Plane Book," by Garrett Hack. This is a good introduction to how the tools work. Another good book, though more limited (and you have to be comfortable with older British terminology) is "Planecraft," reprinted from a mid-last-century tome by Woodcraft and available for about $10-12 from either Woodcraft or half.com.
If you start lurking here, watch out for those who think you need to buy more planes immediately - you can do a lot with just one plane as you start out.
