Strategy
Wiley Horne -- So. Calif.
>Will,
Think about your overall strategy. If you want a slightly sprung edge, do you do it on the machine jointer? Or do you just go for dead flat on the machine?
Case 1. If you're coming off the jointer with the exact edge you want, except it has ripples on it, then I would say get something larger than a block plane, but considerably shorter than a jointer. Just a useful plane, like a No. 4, 4-1/2, or 5, or equal in a woodie. This is because if you've already got the exact edge you want, including spring, the shorter plane will tend to follow the edge you've already created. It's just a smoothing operation. Whereas, if you were to come in behind with a long plane, then in effect you'd be starting over and doing the job a second time, and introducing a chance to mess it up.
Case 2. On the other hand, if you're coming off the jointer with a dead straight and square edge, but with ripples on it, then I would suggest getting a No. 6 or No. 7 (or equal in a woodie), because this will allow you to not only remove the ripples, but also put some spring in the joint (when you want it) with control. You could also spring the joint with a block plane, but with very little control. No. 7 would be the classic plane for the purpose, but I mention a No. 6 (or equal in a woodie) because it would be considerably less expensive and is a useful size all-around in the shop for a variety of jobs.
As in all things, budget matters in answering your question.
Wiley
