Drawer glide material?
Edward in Vancouver
>Next few days I'll be mounting the drawers in my toolchest project, 8 drawers in all.
According to the plans, I should be using a hardwood like maple for the glides. The fronts of the drawers are qswo, with the sides and back maple. Sides have a 3/8" x 3/16" deep groove cut for the glides, and I have prepared glides from off-cuts of the same maple as the sides.
Should I be using another material other than maple since it is the glide that will take a lot of wear and tear? The glides are attached to the sides of the box with only one screw holding them in place at the front and rest on 1/4" x 1/4' glue blocks at the rear--accomodating wood movement of the box and drawers. I do have some teak scraps available, but I was thinking more in the line of solid nylon. Your typical dollar-store nylon kitchen cutting board is exactly 3/8" thick, so cutting off 3/16" slices is fairly easy.
Would nylon make a good glide,or should I stick with maple?
Re: Drawer glide material?
traditional advice
Bill Tindall, E.TN
>The traditional advice is a soft wood for the drawer sides, because they are easy to repair, and a hard wood like maple for the runners which are harder to repair when worn.
Cutting boards are usually polyethylene and it is an excellent material for sliding upon. I have seen it as a wear surface under the chains used to move logs and lumber around a mill. So if it lasts with metal sliding on it, it should do well with maple sliding on it.
Re: traditional advice
Edward in Vancouver
>Thanks, I'll be slicing up a cutting board for glides tomorrow. I've seen nylon used as bushings and even used in gears for machinery, figured it must be worth a shot.
The skinny on nylon
Adam Cherubini
>Nylon is an excellent material for this application. Its cheap, easy to work, and will last and last. The problem with plastics like these as bearing surfaces is that they are so soft that dirt and grit can become imbedded in them, resulting in a sandpaper like surface that accelerates wear instead of reducing it.
So in a relatively clean environment like your shop, nylon should be great. But where loads are higher, relative movement is lower, and grit is prevalent, you're better off (wear-wise) with metallic components.
Adam
Wood
Wiley Horne -- So. Calif.
>Edward,
This is a modest piping up from the back of the room, in favor of either the hard maple or the teak. From what little I've seen of teak, it'll wear like iron, and hard maple not far behind. Wood'll look better, even if the parts can't be seen. Plus all the other wood in the box will be happy, because it'll all be moving together, with no one out of harmony.
Wiley
What Wiley said...
>and if you want to make the drawer slide easier, use what everyone else uses, thumbtacks. (I am just kidding, but I have removed hundreds of them from old bureaus then repaired the soft drawer sides and in fewer cases the wooden drawer guides.)
Stephen
Not Nylon... *LINK*
Scott Burr in Ben Lomond CA
>What you want is UHMWPE (ultra-high molecular weight polyethylene).
I use this for runners and slides. It works easy with wood working tool (both hand and power tools). It won't wear out in your lifetime, or the next few generations for that matter.
UHMWPE
Re: The skinny on nylon
Edward in Vancouver
>Hung jury.... Well, I guess I'll make up my mind later this week. I've got all the drawers completed and planed down to finished height. I have a left and right bank of drawers of 1", 11/4", and 11/2", then a horizontal divider and two full length drawers of 21/4" and 3" in height.
I've had a lot of fun with this project, and had to force myself to slow down and concentrate on doing a good job a few times, but I'm very happy with the results. Kind of reminds me of cooking for some reason, I blindly follow the recipe (actually a very good Veritas set of plans) and find ways to cover up mistakes. I was always told the difference between a professional Chef and a hobby Chef was not the mistakes themselves, but the frequency and how well they were covered...
