We value your privacy.
>A note to those installing a grinder for the first time......These things throw grits, especially with a soft bond wheel. If a grit gets on a board and then said board is hand planed the grit will mill a groove down the sole and through the edge of the iron. Hence, locate a bench grinder is some remote corner of the shop.
Some may be wondering how I know this......experience!
>-For those of you who are pondering aftermarket tool rests, (veritas, Oneway) be sure to take the rubber feet off of the grinder, since most of the tool rests don't actually mount to the grinder. You want to make sure the grinder and the tool rest aren't able to move in relationship to one another.
-Not only do grinders throw grit, they spew metal dust. When I first started, it didn't bother me. One day I wore a mask, as a goof, figuring maybe I was inhaling the metal dust. The mask got pretty gray. Wear a mask, if you have one.
-Grinders are big dumb heavy spinny things. (That's what I say to the non-woodworking crowd, or to three year olds)
-Friable wheels are great. Get the coarsest one you can, since the surface quality of the grind doesn't matter, and the faster the metal gets removed, the faster you're done, and the cooler the tool will be.
(not applicable to turners, since many of them use the tool right off the wheel)
-If you're hungover, it's easier to grind your tools, because you have a headache to keep you company while your tools are cooling down, and you're not really so concerned with the passage of time.
-If you're hungover, it's not much fun to grind your tools.
-If you're hungover, it's not really much fun to do anything.
>"-Friable wheels are great. Get the coarsest one you can, since the surface quality of the grind doesn't matter, and the faster the metal gets removed, the faster you're done, and the cooler the tool will be.
(not applicable to turners, since many of them use the tool right off the wheel)"
They are faster cutting but they create a much larger environmental disaster. I'm not sure the trade off is worth it. Most of the stuff I grinder is HSS, either turning tools or metal working tools, so overheating is not a problem. I don't grind really high quality hand tools, but even if I did it's just a mater of pace not to burn them on the hard wheels. If I need to remove a lot, a belt is a far better option than friable wheels. For some tools the harder wheels push up a better burr which can be what one needs.
Most time I just come into the grinder with a deep breath in place, run the grind, switch off, and I am out of there.
>Yeah, you're right... all of you are. I wasn't hungover, I'd actually just then been drinking. And clearly, when I've been drinking, I shouldn't go near anything with a cord... including a computer. :)
