THE WOODRAT IS BACK!
Tips on rehabbing old wooden planes? Dust and mold
wilbur
>I've been going over the wooden planes in my recent haul more closely. I've never restored/rehabbed a wooden plane before, so I'm hoping to get some pointers.
The two main issues I see are dust/dirt, and mold. I was thinking about using an old toothbrush along with a slightly damp rag to get the dust and dirt off, but I'm not sure if this is the best way.
The other issue is mold. Some of the planes (not many, thankfully) have some mold growing on them. What's the best way to deal with this?
I don't have any evidence that these planes are particularly rare, so I am not worried about destroying a piece of history here. My main priority is to get these into working order, as best as I can.
Thanks!
Re: Tips on rehabbing old wooden planes? Dust and mold
REAL mild bleach and water solution?
Dominic Greco in Richboro PA
>Wilbur,
I think a real real mild bleach and water solution is the ideal way to get rid of mold. I have NO idea on the proportions to use. I just know that it's got to be so weak that it doesn't bleach the wood, but have enough "oomph" to kill the mold.
See ya around,
Dominic
Wiley Horne -- So. Calif.
>I haven't dealt with mold before. And if its an 18th century collectible, that's a different ballgame. But to clean up users and get them back into service, I like to use Briwax (clear), rubbed in with 3/0 steel wool, and buffed off by hand with a cotton rag. This removes the dirt and grime and leaves a glow on the wood. But it doesn't look skinned and refinished.
Wiley
One other thing you can do (carefully...)
>If you feel you actually want to remove a layer of something from the wood--dirty mold maybe--here's a thought. Lee Valley sells these 'superhard, superthin' scrapers:
http://www.leevalley.com/wood/page.aspx?c=2&p=49548&cat=1,310,41069&ap=1
Because they're real thin and bendy, these things have a very soft attack. But they come jointed, and all you have to do is put a burr on them. At that point, they have a soft attack, but they're very sharp. I have many times removed a single layer of thinned shellac from wood. They're great denibbers, too. Point is, you have enough control that you can remove a very thin layer from wood, and with any touch at all, they will not leave you looking at bare skinned wood. If you can do surgery--and I know you can--you can use these scrapers for delicate removal. Leave one edge without a hook for the softest touch.
I always have these close to hand.
Wiley
Jim in Burlington Ont.
Paint thinner
>I wipe them down with paint thinner first. Get's rid of any wax and some dirt. A little green scrubber pad helps. I don't really like my old planes to look fresh and new just clean enough to make them useable.
First, I agree with everything about...
Ted Owen, Pittsburgh
>not doing anything to harm the value of a true collectible. But it sounds that you're like me and bought the planes to use them. So here's what I do.
Clean all woooden and metal parts in Murphy's Oil Soap and warm water. I plunge even the plane body into the bucket of water. Use a soft brush where needed, soft toothbrush for tight quarters, but you may get by just washing with an old dishrag. The dishrag is all I do on the metal parts, but they get cleaner in the next step, so you don't have to get them perfect at this stage.
Dry immediately and thoroughly!! Use a hair dryer if you have to, but get everything dry within 60 seconds.
Then I take the parts to a Beall buffing setup, popular with woodturners, which I use on a Shopsmith. Except for the wedge, Beall buff the wooden parts with Tripoli, then White Diamond, then Wax. The wedge should remain unfinished where it friction fits into the plane body, though I do buff the top just for looks.
Buff the metal parts on a burgundy ScotchBrite wheel. Don't do this on any Nickel plated parts, but they're usually not present on older wooden hand planes anyway. Then perform the same Beall 3-steps with a different set of buffing wheels--dirty metal makes the buffing wheels dirty quickly, but they still work. Then shape, sharpen, hone the blades as necessary and finger-tip apply a touch of Carmelia Oil.
Reassemble and enjoy using. When I use the old wooden hand planes, I always think of the former users and hope they would be pleased.
Best, Ted
Todd Hughes
>I clean lots of old wood planes. What I do is take them apart spray the wood with some regular WD40 and while still wet scrub them with some fine steel wool. Don't go crazy just remove dirt etc. Any paint splats get popped off with a chisel blade. Then wipe down with a clean rag. Will leave a plane that is clean and presentable but doesn't look like it has been monkeyed with. Personaly I don't like to wax them because then you get a plane that looks like it has been waxed, probably not a big deal though but I think some people don't like it
...WD40 works great to remove small paint spots and dirt while giving the wood a natural look.....Anyway what works for me and I have sold a truck load of wooden planes cleaned this way and never had a complaint....probably because while clean they didn't look like they had been cleaned....Todd
ammonia
Adam Cherubini
>Wilbur,
10% ammonia is good because it cleans well and leaves nothing behind. All the other stuff folks have mentioned leaves something. This is also a good choice for fine furniture. Just be careful because ammonia is pretty strong stuff. Even 10% can strip away stuff you'd like to keep. I wrote an article on restoring woodies a few months ago. You might want to check that out.
Adam
NH3, only on woods low in tannic acid...
>Oak, chestnut, sycamore and ash as well as some other woods are darkened by ammonia.
I wash them with soap, not detergent to clean off the human. Add a bit of bleach to kill the mold or put it in an atmosphere of chlorine bleech to kill the mold.
I then generally work over the wood with linseed oil as it needs it and remove the rust from the irons. Sharpen them up and use them and this won't happen again.
I like Todd's advise on WD40 (Save this one Wilbur) as it does exactly as he says, the tools are clean and don't look like they have been cleaned. Also that stuff is only on the surface so it isn't going to cause any harm. Great tip Todd.
Stephen
paul womack
Wise words, indeed :-)
BugBear
Like beech?
Adam Cherubini
What's the matter with ebonized panes?
James Watriss
>I think they're cool. They have that whole Darth Vader, basic black look to them that says "This tool is not to be messed with."
Which is good, because I don't like people messing with my tools.
I'm getting punchy, so I'm going to quit posting for the day. This is what I get for drinking beer after a 3 hour bike ride.
