Canoe paddle epilogue
Dave Mount, NE Minnesota
>Thanks to those that responded to my question below. While I don't doubt those other approaches were successful, I'm very impressed with the "Rock Guard" feature of the Bending Branches paddles and decided to (attempt to) replicate it. As pictured below, I made a mold by tacking some cleats to a piece of p-board, then coating the inside with melted candle wax to make it release. I then poured the cavity full of a mixture of epoxy and fine sawdust. A pic in the ensuing message will show the piece out of the mold. The lighter color of the epoxy in this pic is caused by fine bubbles that rose up out of it. The next pic shows the bulk color.
The blade was left flat in cross-section while I did this pour. After I profile it and shape the edges I'll cover both sides with 2 oz fiberglass, overlapping onto the epoxy edge. Paddle blade is a cherry and walnut lamination, the shaft is solid cherry. This one is the "test" paddle that I'm taking through the process to work out the bugs. I have four more blanks glued up; my plan is to give a paddle to each of the travelers on our Boundary Waters trip planned for June. The grip of each one will feature a different wood so they can be differentiated easily. Lots of drawknife and spoke-shave work ahead.
Best,
Dave
Re: Canoe paddle epilogue
Re: Rough blank compared to the original
>Here's a shot of the blank fresh out of the mold compared to the model paddle. For those concerned about patents, I'm not selling those I'm making.
Dave
ThomD
>A few points:
- If you build with all the glass you are using (good choice) you don't need anything more than cedar in the paddle. A light paddle is an incredible advantage, even in the wilds.
- When doing glass I normally have a power face, and I glass that first. Then I remove as much wood as required for the paddle to seem a little flexy and weak, and add the second layer of glass. Harder to do if your blade is symetrical. At least for me, I have a hard time getting things non-clubby when I glass a paddle that hasn't gone through this process.
- I normally glass on both sides then trim back the bottom leaving a little extra. When wetting out the glass it is normally wetted out with a little run-wild. Once hardened off that's an easy place to insert roving, or whatever you want, for the tip.
- I like an oil finish on the grip, but a gloss poly finish on the shaft. I cut back the gloss finish with 360 where the lower hand goes, that will basically eliminate blistering (except as inevitable with really soft hands).
I gear up, in both senses of the word with: 1 freestyle lam wood, or 1 whitewater, or 1 solid wood freestyle paddle; and 1 carbon bentshaft. I basically try to have one paddle for wind and one paddle for whatever kind of control is on the agenda, and I try to carry 2 paddles.
I built my first bent shaft laminated wood paddle around'78, I've learned a lot since then. I have to say thought that the Zre carbon recreational paddle I bought a while back taught me more about paddles of what I still didn't know, than anything else. I have to say carbon makes anything else seem like one is harvesting seals. And the edge and foil treatments are drastic for control also.
One thing I like doing on wood paddles is binding the edges with a contrasting wood. A guitar holdover thing.
sage advice
Bill Tindall, E.TN
>I have found all your points on paddles to be true in my hands except the carbon part where I have no experience and I am probably too frugal to get any.
can we see some?
Tom Sontag - St. Louis
>Thom,
Sorry if I have missed you posting pictures of your paddles in the past, but I would be interested in seeing some of them.
Also, it seems to me you know enough about this subject to write a really interesting article. That means work and time, I know, so I only mention it.
Alan S
>I don't have anywhere near the experience of your other responders in making paddles, but have one comment for your next one if you put on this hard edge. That is to consider epoxying the entire blade either while you do the edge, or just before. Sometimes the edge shows where the first epoxy wet the wood, even when you coat the entire thing with epoxy later.
Re: can we see some?
ThomD
>I'll see what I have kicking around. Mine aren't all that spectacular to see since I tend to look down my nose at contrasting woods: whenever I see one piece of wood next to another I want to know what the purpose of that was. I try just to put stuff in to improve the paddle. If I worked at it hard enough to come to a conclusion, I would possibly then make a fancy version, but I always have the next improvement in mind. And then I have to need a new paddle... Only one ever broke, it was thinned down like the limb of a bow and had a carbon spring, that broke. If one never breaks them One hasn't got them light enough, so I guess I still have a way to go.
I got started back in the 70s when Mike Galt was writting all his promotional pieces on solo canoeing. He wrote an excellent article in Wilderness Camping on making bent shaft paddles. I started with that, got a little bogged down on my first canoe project, and scratching around for inspiration to get me re-started, I found Krenov's books. The rest has been a long and hard fall! :)
Re: sage advice
ThomD
>Thanks Bill!
I was lucky on the carbon thing. I found one marked down at the end of season. It was still about 75 or 100 bucks. The first time I had it out, I had a commercial paddle that was average weight and the Zre out. I paddled with the long paddle until the winding road ran out, and I hit a bit of a windy open section. I used the Zzre marathon through there. When I got back in the sheltered area, I picked up the regular long paddle, and it felt like it was made of stone. Made a big impact. Quite a bit has been written about paddles that have good ballance not being terribly "heavy" in the hand, but after that I knew net weight was huge (same is true with planes). I had always built cedar paddles so I thought I knew low weight. Zre sells (last time I looked), all the components, so one can buy just the shaft, or grip. I have a back burner project to make the kind of paddle I like out of the parts, That will require a blade mold, but if I ever get to it, I think it will be amazing (as far as pleasing me is concerned, at least). I learned a variety of other interesting things from that paddle.
here are two.....
Bill Tindall, E.TN
>I have the same view of contrasting wood but in this case it is sap and heart red cedar. Red cedar has huge bending strength and I think it makes an excellent paddle.
Re: here are two.....
ThomD
>I like those. I just don't try for contrast like basswood and cherry or something. I may have naturally occuring contrast, just as you have there.
This is a five degree freestyle paddle I am working on. The near face has been trimmed back (so it looks a little wiggly), while the far face still has a lot of run-wild on it. The walnut binding can be seen along the edge, it will stand out well when the glass is trimmed back properly. I have to admit the binding is a contrasting wood thing...
Doing the binding was easy. My paddle tip is fairly square, and I can chose a radius from my hot pipe for the corners. I used masking tape to support the outside of the 90 degree bend. The rest is just shaped freehand. Two pieces are are used and they meet in the middle at the bottom of the paddle. The binding is just taped, on with masking tape. You can use carpenter's glue, or you can tape it down so it is all in place then wick super glue into the hairline crack.
I have to make one of these colour combos some day, just to have a flash paddle, but I prefer to paddle with paddles that feel good.
http://www.woodsongcanoes.com/images/paddle-2f.jpg
http://www.woodsongcanoes.com/images/paddle-2e.jpg
Maybe maple veneer over foam core.
I have four paddles in process now, but none of them is at a photogenic stage.
