Canoe paddles - epoxy filler question *LINK*
Dave Mount, NE Minnesota
>Hi all--
I'm making a run of canoe paddles and I want to pour an epoxy edge on the bottom of the blade like several paddle manufacturers do (e.g., Bending Branches, see link below). My plan is to pour the edge, then do final shaping to feather it into the wood, then put some very thin fiberglass (e.g., 2 oz) over the entire blade, lapping over onto the epoxy rock guard.
My presumption is that I should use a filler of some sort when I pour the rock guard. My question is whether just using fine sawdust off the bandsaw will be OK or if I should use something else. I'd rather not buy commercial filler unless there's a real need to. I thought by using sawdust the rock guard would kind of blend in in terms of color.
Thoughts?
Thanks,
