I need to radius my arris. What tool?
Roy Anderson
>I have a set of table legs and I don't want to leave the arrises (arri?) sharp. I want to put a radius of about 3/8ths inch on them. And the trick is I don't want to use a router (the electron eating kind).
So what tool does this present me with the opportunity of getting?
Re: I need to radius my arris. What tool?
Re: I need to radius my arris. What tool? *LINK*
paul womack
>Buy or make a beader/scratchstock.
BugBear
info
paul womack
>Oh, and Lee Valley (Veritas) claim to have a new model in the pipeline.
BugBear
Man, that's gonna hurt... :)
Rob Lee
Rob Lee
>Hi Paul-
Yeah - it's coming...!
Just wrote the June catalogue letter about our production schedule... and how it's like a snake passing tennis balls ....
Availabilty on that one is currently Aug 22nd.... afternoon, I think...
Cheers -
Rob
Roy Anderson
>Darn!
I already have the Veritas one. I just need to cut one of their blanks to the right radius.
What's the best way to do that? I'm not really tooled up for milling hardened steel.
MikeW
>Roy, I just use a chain saw round file for shaping small curves into scraper blade stock. If you are really going for a large radius as you mention, I would draw it on the blank with a Sharpie and file to the line.
For just knocking the sharp edges off--i.e. not putting a larger enough radius to notice--I use a block plane. Anything larger and either I use a scratch stock so there is some sort of consistent radius. Using a round needle file would produce a very light radius.
Take care, Mike
Marc in Luxembourg
>Roy,
The blanks normally come unhardened. You shape them with a hacksaw, a file or whatever works for you. You can harden and temper them yourself or - not. For small jobs it isn't always necessary. Sharpening with wet and dry glued to dowels of the right radius.
Hope this' helpful,
Marc
working American cherry on Labor Day
Dave Anderson NH
>I'm with Mike on this one. Just a quick swipe or two on each arris with a finely set block plane leaves the overall tapered rectangular shape and removes the chances of the leg getting dinged and torn up.
GolfSteve in Calgary
>You can do a pretty fine job with just a block plane and a good eye. 3/8" is a pretty large curve, but planing a nice round edge is easy.
If the legs are curvey use a spoke shave instead of a block plane.
If you really don't want any evidence of the tiny facets left by the plane or spokeshave, 60 seconds per leg with some 400 grit sandpaper will leave a perfectly rounded corner.
Just take your time and plane carefully with purpose.
I disagree
roninkokomo
>Small diameter round or is it hollow :) plane is just the ticket. There is a radi plane on the market that is cheap and works like a champ.
Back when I actually went into the shop to work, it stayed in my apron pocket because I used it all the time. They also make one that champhers.
Yeah, and I sure wouldn't talk about it in public!
Bruce, a MN Galoot
The plane, right? Not the....
Scott Burr in Ben Lomond, CA
>Lil' bent metal ones? I tried those metal ones, they failed miserably.
I think a lot depends on the effect you want
>There have been several competing proposals, all of which contain several competing design ideas. If you want a 3/8" roundover that is as smooth as a router will leave but without a router, you can get there with several of the tools proposed; or you can go for the slight irregularities that a block plane and sandpaper (or a card scraper) will leave behind.
I think you want to describe to yourself what you're trying to achieve more explicitly before deciding on the suggestions made.
Jack Guzman from Maine
Hand scraping moldings
>When I want to break a sharp edge I use a block plane. When I need a particular radius,I make the profile I want in a small piece of flat stock(unless I already have that profile)and use it either freehand or in a simple scratch stock holder(see Bugbear's website) to get the exact radius after planing.Sometimes I can scrape the radius without planing.Depends on the wood and depth of material to be removed.Once you start doing this you'll see it's not that far a stretch to shape your own simple molding profiles by scraping....Jack
#6 hollow plane
Larry Williams
>You'd have it done in less time than it took to compose your question or read the responses if you find yourself an old #6 hollow in decent shape. If you get it nice and sharp, it'll even work across the grain unlike the scrapers some are suggesting.
Re: The plane, right? Not the....
roninkokomo
>Yes the plane
Moses Yoder
Re: I need to radius my ars. What tool?
Moses Yoder
>I agree that you should ask yourself why you are putting a 3/8" radius on it. Everyone who looks at it will just think you took a router and rounded the edge. Kind of a production thing. I know because I do a lot of production. So if you are going to put a 3/8" radius on it, you might as well do it with a router. You are probably thinking about people banging their knees into sharp corners. I find that 3 or 4 passes with a sharp block plane will ease the edge just right. It leaves a small facet so that anyone who looks at it in depth will wonder how you did it. Very few people will actually know how you did it. If you ease the edge with sandpaper it leaves a rounded dulled corner. The facet on the corner will ease the edge enough that when you run your fingers across it will feel smooth and not sharp. It leaves the impact of a square corner wihtout the danger of it splintering. If you are looking to soften the impact of the leg then go ahead with your 3/8" radius; I just thought I would dump some thoughts out and see what happens.
Re: That's ARRIS, not A?$E!
Roy Anderson
>You boys are bad! Bad, I say!
My A?$E could use a little radiusing, too, actually. Probably a bowflex rather than a block plane for that.
Does a block plane work on bone?
Marc in Luxembourg
>Your thoughts - Moses - putting the whole in a wider context which it is very difficult to visualize, I suggest Roy should post a pic of the table. Meanwhile I am on your side, as to make hand work not do look like machine work. Sometimes nonetheless one has to build a piece that will go into an industrially made environment - a living room i.e. That's the reason that works for me.
Marc
p.s. joiners on boats made planes out of whale bone, but did they made those with their current wooden planes?
Re: #6 hollow plane
Marc in Luxembourg
>Larry,
You write:
If you get it nice and sharp, it'll even work across the grain unlike the scrapers some are suggesting."
Now you drive me to put my molding planes to more use. Sharpening the iron isn't quite enough, because they're old and the wooden body has shrunk, the iron not. Got that cleared by watching Don's dvd on molding techniques. I'd like to have one high quality molding plane to see what it is capable of...
My question is, was it current practice to use molding planes on end grain, like on a simple table top or on a drawer front, let's say anytime before WWI?
Marc
You mean like this?
Larry Williams
>Here's Don sinking a cross-grain ovolo in curly maple. I have a late 19th Century British oak sideboard with the top molded across grain, my daughter has a ca. 1920 British mahogany dresser with the same thing and Don has been talking about doing an article on a late 17th/early 18th Century technique of cross-grain moldings. So yeah, it was done and wasn't all that unusual.
Thank you Larry...
Marc in Luxembourg
>And keep us posted at Don's article. I'll be eager to read it.
Marc
