San Antonio Mission Woodworking
Roy Anderson
>I just got back from a trip to San Antonio. I was on the lookout for woodworking items throughout the trip and I found some.
We took a tour of the old Spanish Missions there (circa late 1600's - early 1700's) and I noticed some hinges on the old doors. They didn't use normal looking hinges, but something that resembled a split brass fastener from a loose leaf binder.
The picture below shows how they drilled a hole in the door and the jam and linked some iron rods that had been bent over. Then they bent back the ends where they protruded from the holes on the other side of the door frame. This sounds incomprehensible until you see the picture.
I can't see why this system is better than a normal hinge, except that it doesn't require screws, which might have been difficult to fabricate in a frontier environment.
Any ideas?
