Question for owners of LV Small Plow Plane
>My very own small plow plane came yesterday - no time to put it to actual use, but of course I fooled around with it and am impressed.
One question for other owners: the screw for adjusting depth of cut is rather sloppy, or maybe the threads in the body are. With the iron set at normal depth of cut, I can wiggle the screw back and forth about 1/16" (an unmeasured estimate from years of experience, and roughly 1.5875mm, for those using the metric system). On a tool that otherwise feels like it was built by a machinist for a machinist - I could spend hours just sliding that fence back and forth, trying to figure out where they hid the ball bearings - this play stands out.
Do others who own this plane find the same play? I've written LV's customer service, but late enough on Friday, Ontario time, that I don't expect an answer until Monday, since even elves deserve time off, but thought I'd ask this group too.
Re: Question for owners of LV Small Plow Plane
>Hi Bill
I pulled out my plow (plough) to see if mine was the same.
My worst case scenario is an approximately 1/32" wiggle ... BUT ...
Try this ...
1. Make sure that everything is done up correctly and adjustment screws are tight. This includes pushing the blade against the inside of the body and tightening the side (clamp) screw.
2. Now loosen the lever cap screw slightly and use the blade projection screw to move the blade slightly forward. Re-tighten the lever cap screw. Now there should not be any wiggle at all.
Measured play last night
>and it's less extreme than I thought - about the same 1/32".
Played with it some, too - NICE little tool. Setup is way faster than my Stanley 45 (although, if I could leave the Stanley set up at all times, it would be quicker than the breaking down to store in a box I do now), and the fence adjustment is superb.
Making a little storage box for this and its irons will be a project when shop time becomes possible again.
