Masking off for shellac?
Paul Kierstead
>I am trying hard to learn my lessons and do some of the finishing (particularly interior finishing) on a cabinet before final assembly. So, I mask off the glue areas using blue tape and shellac away (both brush and wiped on). Alas, the blue tape does not seem so impervious to shellac's charms.
Anyone one have a particular methodology/materials they use in this situation that works well?
Re: Masking off for shellac?
No paper based tape...
Scott Burr in Ben Lomond CA
>Try a vinyl based tape with a smooth surface (unlike masking or duct tapes). Packing tape should yeld better results although a bit harder to remove.
Warren in Lancaster, PA
>Paul, I remember an Ian Kirby article around 1982, subtitled Avoid the unseemly rush to glue up. I sometimes do finishing before gluing. I have never done any masking at all, but I think the materials I use are more forgiving than some. I use waterstains, shellac and hide glue. I can imagine oilstains and yellow glue might give some problems.
Next time...
>after you have masked the joint, rub it down with a bone folder or small piece of hardwood dowel. Then talc the tape joint and wipe off the excess talcum powder. This will prevent shellac or paint or varnish from migrating under the tape.
Stephen
Re: Next time...
Paul Kierstead
>I did rub down (though with a metal roller, I'll just try a dowel too), but the talc is a very interesting idea. Indeed, it seems the shellac slides under the tape, not goes through it.
Re: Next time...
>This is a trick I got from a billboard sign painter, the talc gets stuck to the tape, fills the holes and resists, shellac, paint or varnish but doesn't effect the finish.
Stephen
Re: Next time...
ThomD
>Talc is amazing stuff. though apparently toxic in certain regards. It's great to coat the skin with before sanding nasty materials like fiberglass, or other nasty dusts. Just as the barber talcs skin to stop the hair from getting in and itching.
