Finished the joinery on this piece today...
>I still have some work to do on the rockers, some chamfering and I will glue it up. I still need to make slats with a 1/2" between for ventilation but I will nail those in place after it is painted.
It was a fun project and took about 16 hours not counting the turnings, had my apprentice do them. Have a couple more hours and it will be done. It is based on a couple of traditional designs.
Stephen
Re: Finished the joinery on this piece today...
John H. in Baltimore
>Very nice!
I'm embarking on a similar project and would like to know how you designed the M&T joints at the head and foot of the cradle. I plan to provide space for expansion/contraction in the top mortises. Does your design provide for wood movement (or is it small enough to not be a concern)?
Thanks for posting this!
John
Nice paint job, it looks like pine brush marks!
Alan DuBoff
>John,
The wood is very dry (air dried) and it is quite dry out West, so I didn't allow for expansion and contraction, but I din't think it will be a problem because of the small size and the double mortices.
The mortices are square, I could have angled them but I didn't, they are not that deep. The tenons were cut at the required angle with a single cheek on the outside. The head board and foot board have cut outs (cupids bows) and I think the cut out will help. I have also added some matching chamfers on the upright posts.
I cut the head board and footboard to 5 degrees, cut out the cupid's bows and sawed each of the tenons to fit the mortises.
Stephen
L. Hanson
>I see where you used your ellipse engine! Thanks for the photos, it looks great - a classic design!
Leif
www.norsewoodsmith.com
The Ellipse Engine performed....
>flawlessly and I was easily able to set it up to do any part of an oval I need.
I am going to post a video of the Oval Making Machine or Ellipse Engine, in use on my blog soon.
Stephen
Jack Guzman from Maine
For now....
>..would you have a picture of it? Ellipse engine? Never heard the name before.Is it something you invented or a reproduction of an old tool?I'd like to hear more.I must have been absent that day.
I really miss the chats, but my day starts at 4 AM these days and ends at 9PM. Even if I logged on I'd fall asleep during the chat.---Jack
Re: For now....
L. Hanson
>Look on Stephen's blog page fpr a photo of his "ellipse engine":
link....
L. Hanson
>Here's the link... it obviously didn't make the last post
http://www.fullchisel.com/blog/?p=70
Video *LINK*
>Here is the video I shot today showing how it works, it is on my blog.
Stephen
Full Chisel Blog
1/2" seems big
>fine for ventilation, but it seems like enough for a baby to insert fingers and get stuck. Is this because it's historically correct?
Re: 1/2" seems big
>Bill,
1/2" or slightly larger is what I have seen in most traditional cradles of this period. I have seen ones with solid bottoms as well. There would be a tick in the bottom and blankets, &c., so I don't think it is a problem.
The spacing on spindles is 'street legal' as they are 4" OC, but so were the old ones, so just copying what already is there.
I think ventilation and drainage is important, I have repaired a couple of old cradles that had damage to the slats.
Stephen
Re: The Ellipse Engine performed.... *LINK*
paul womack
>Apparently the design is rather old, sometimes called the "trammel of Archimedes"; I've not heard it called an "ellipse engine" before.
I think "elipsograph" would be more conventional.
BugBear
animation
Chris Friesen
>I've always heard that there were standards about baby cribs...things like not having vertical projections that could suffocate a child if their shirt caught on it, not having gaps big enough for a baby's head to fit through, etc.
Do you think these are not really factors of concern?
>Chris,
No, I do think those things are important, this is for a museum and will probably not be used. I don't know how I can design it any safer, it has kickers on the rockers so it can't readily tip over.
The spacing between the spindles is 4 inches, which I think is the requirement. The small openings might be a problem and if I make any for resale, I will have to include a disclaimer.
Stephen
