Marking tool binge
Marking tool binge
Marking tool binge
Dave Mount, snow's almost gone
>Took me longer to finish these than I was expecting (life threw some distractions at me), but I finally epoxied the business ends in these. Top four are osage orange, bottom four are crotch cherry (two of them not so much, those were the first practice pair). The knives started as 1/16" x 1/2" O1, I ground two of them down to 3/8 wide. Awl points were made from drill rod, all hardened and tempered to 62 Rockwell. Ferrels are reshaped from flare nuts.
I don't know why I waited so long to get a lathe. . .
Best,
Dave
P.S. To save someone from asking, the background is a piece of flagstone. I made two side tables and a coffee table that are slabs of this stone with a cherry undercarriage.
Re: Marking tool binge
Re: Close up of crotch cherry pair
>These were some sweet pieces I cut out of some 4/4 boards years ago and threw them in a back corner of the shop for that someday when I bought a lathe. Amazing that I managed to remember them. Unfortunately, there was a flaw in the blank for the marking knive and I had to go a little deeper to take it out, hence the pair are not very symmetrical. I'm going to keep this pair anyway.
Sweet!
>Nice tools, Dave.
Ummm...Dave?
Steven Kubien
>You may have made one strategic error...You bought a lathe. I used to be pretty serious about my handtools and flatwork in general, until I got a lathe to make some chisel handles. Hmmm, those chisels are around here somewhere. Maybe under this pile of shavings? Or, behind those bowl blanks? No, wait, they are with my smoother! Now, where did I put that?!?!
Good luck finding balance.
Steve Kubien
I thought Purdy made paint brushes?
Re: Hazard noted. . .
>I can see how it could be a black hole. So far I've only gotten one boot stuck in the mud. This weekend I made myself put it away to get some other projects done. We'll see how the willpower holds out. . .
Come on Scott, take the plunge. . .
Best,
Dave
Nice looking tools!
Alan DuBoff
Glenn Madsen, SF Bay Area
>The problem I had wasn't the $1000 for the lathe. It was the multiples of that for the 'accessories'. Who knew?
Yes, used to paint the cherry and osage grain!
Alan DuBoff
Re: The Real Hazard
ThomD
>The Hazard with the lathe in addition to the main points made, is that it is fast, everything else is slow, until you fully fund the electrons for a bandsaw, grinder, dust collector.
If you really want to save money you should have bought a metal lathe first since you can make pretty much everything turning requires on a metal lathe, particularly if you turn like Ed Moultrop, or the Japanese. Of course that leads to a mill, because it sounds wholesome; and you only have to see a shaper once and you will need to buy one of those. How I ended up with 7 metal and wood lathes is hard to explain, and increasingly it's getting harder to to find anything. I used to have a shop...
Re: Accessories. . .
Dave Mount
>Man, I can see that loud and clear. This reminds me of getting into blacksmithing. I looked at it initially and thought heck, here's a tool unintensive activity, a hammer, an anvil, make a forge and that's all there is. Hah!
Best,
Dave
Hey Scottie,
>I'll ship you a little lathe (10" swing, 30-36" center to center, think it would go in parcel post, needs a little work) for postage and whatever you decide to donate to Wood Central...
Hee hee...peeeeeeerr presssssssure
