Brace Chuck Question
>These are a couple of braces I use in the colder weather, they have wooden handles. One is made of apple, the other beech and neither is marked.
One has a conventional taper chuck with a thumb screw. The other one doesn't.
Stephen
Re: Brace Chuck Question
>Here are the chucks to compare. I think some sort of spring mechanism is missing but I am not sure. I checked some sources and haven't seen anything, but I seem to recall a U shaped spring projecting with the closed part up and the open part down? If I knew what it looked like I could have it replicated.
It still works to hold regular tapered bits, but there must be some reason for the channels.
Stephen
flat tang bits
Adam Cherubini
>Those channels were probably filed by the user to accept his flat tang bits. That's a penny brace. They were cheap and plentiful in the 19th c. A past owner, like us, may have had several antique tools in his shop! Flat tang bits are usually 18th c, designed to be fit in wooden pads or pods.
I wish he hadn't used those antique bits but rather passed them down to his witless ancestors in pristine condition who unknowingly listed them on ebay as "playmobil" or "lego" or something similar that I search ebay for but few old tool collectors do.
Adam
I thought those things were can openers...
>I have actually seen only a couple of flat tang bits, just never thought that this brace was made for those, hum.
I looked at some other photographs of the brace, and I am fairly sure it is cast and part of the original. I thought maybe for a spring to hold spring chuck bits, but the thumb screw would do that.
I just never thought of flat tanged drills, a bit before my period of interest.
Thanks Adam, and we get cross cut saws in my century.
Stephen
