Stanley/Record 71 router plane parts
wilbur
>It seems that these planes often have the fence, but are missing the bolt that holds the fence onto the body. Is it hard to replace this bolt, or is it some sort of oddball screw size?
Re: Stanley/Record 71 router plane parts
Knowing Stanley...
Scott Burr in Ben Lomond CA
>It's probably an oddball size. I'm not sure about Record tools.
You can probable get one from the stanley parts web page. You can try to match it up with one from the hardware store. If all else fails re-tap the hole to a common size and your good to go.
Re: Stanley/Record 71 router plane parts *LINK*
>On my type 14 (1953-1973), it's a 10-24 standard machine screw. In my limited experience, Stanley tended not to change a screw pitch once it had settled on one (they clearly did not anticipate that everyone would adopt this screw pitch, or they'd have chosen something different...). Link to type study below. Get yourself to the hardware store or your jar-o-machine-screws and try that pitch on yours.
Interestingly, you can apparently still build yourself a brand new router plane from parts available on the Stanley website, here below. But they list just one cutter for it, the straight cutters having apparently sold out.
http://www.stanleytoolparts.com/
Stanley router plane type study
Viewing Problem
David Miller from Iowa
>This is weird - I can't see the text in Wilbur's or Scott's post, but Bill post is fine. Any ideas (and don't say "preferences":)
That's because we're using...
>The new invisible type keyboards. Wait where'd it go...
I have this problem
>between work (oh, how I hate saying that word! I thought I'd retired) and home. Work doesn't work, and it's not because they're blocking; there's just some setting issue that I haven't taken time to resolve, because I feel guilty enough already about the rate they're paying me. I just wait until I'm home to see what pearls of wisdom Scottie has laid on us all.
It's erratic. Ellis, I think it was, suggested to me that clearing the cache of cookies, history, etc. on the browser should help (on Internet Explorer: tools/internet options/look for "clear x" stuff).
Re: Viewing Problem
Tim Caley - North Little Rock
>I'm having the same problem on one of my PC's. The one that uses Mozilla doesn't have this problem, but the one with IE6 does. If you do View - Text size and choose a larger size the text becomes available.
Re: Viewing Problem
Skip in Falls Church
>I have the same problem on the computer at work that uses IE6. Some posts show up and others don't. But I've found that if I highlight the area of the post the post is there and will show up. I don't have the problem at home on either the AOL browser or IE7.
Skip
