1" LN chisel
1" LN chisel
1" LN chisel
Chris K in MD
>I just bought a 1" LN chisel and the handle is bigger (similar shape of the others about 1" longer and bigger diameter than any in the set. Anyone have one and experiance the same?
Re: 1" LN chisel
Re: 1" LN chisel
Nick Tuzzolino
>This is a good thing. I have the 5 piece set of LN chisels and the handles are made for very small hands. They are actually wimpy/petite to me. They are the smallest handles I have ever seen on chisels. First chance back at the lathe, I'll turn a set for larger hands.
Re: 1" LN chisel
Re: 1" LN chisel
>I have the LN set and I like them a lot but the handles drive me nuts. I have making new handles on my "to do list".
Tom
Re: 1" LN chisel
Re: 1" LN chisel
Raney
>I have the 1" and the standard set. The 1" does indeed use a larger handle.
Re: 1" LN chisel
Re: 1" LN chisel
Bruce, a MN Galoot
>I don't have the LN's, but I do have or had Freud, Hirsch and Berg. In all cases, the 1" were larger than the others. In general the larger sizes had bigger handles, starting at about 3/4". The 2" Berg is pretty good sized. But then, it should be.
Bruce
Re: 1" LN chisel
Re: 1" LN chisel
Chris K in MD
>Thanks all, further inspection the blade is 3/4" longer too!
Re: 1" LN chisel
Re: 1" LN chisel
>Hi Chris
This sounds a standard practice to me. As the chisel gets wider, the handle should be larger for more control. That's how I see it anyway. It is what I did when I re-handled my Bergs.
Here you can see the size of the Berg handles increased at the 3/4" mark. My three larger Bergs are 3/4", 1", and 1 1/4". I might get a 1 1/2" if I find a good one, but this is about as large as I like them. At the other end of the spectrum - see the smaller set of handles - they go down to 1/8".
Re: 1" LN chisel
Re: 1" LN chisel
Raney
>I agree with everyone that this is pretty standard, and individually-sized handles are a mark of careful design. I feel I should point out, though, that the handles are not graduated throughout the line as some vintage sets would have. The LN 1/8 - 3/4 set I have all use interchangeable handles of the same size. There is merely a single 'step' increase for the 1" chisel.
Re: 1" LN chisel
Re: 1" LN chisel
Marc in Luxembourg
>Hi Chris,
I have the 1 inch and the 1/2 inch chisels. The 1 inch has a bigger handle. I too like to use it over the other one. Perhaps it is worth to note that the taper going into the socket is the same. So a big handle fits a small chisel. One can easily turn a bigger handle (taper is half an inch to a quarter inch over the length of an inch) or maybe ask LN in Maine for the bigger handles instead of the small ones.
Cheers,
Marc
