Nuts on a Disston Backsaw
David Wheeler
>I have a very nice 1888-1893 14" Disston Back saw; and I wanted to take the handle off to fully clean the blade, but I can only get the screw with the brass button; and one of the other screws to come out. The third one spins when I try to back the screw out. There is nothing to hold on to to loosen the screw. Is there some trick to get it out?
Thanks.
Re: Nuts on a Disston Backsaw
Mike Hamilton
>David,
Best trick I've seen listed was to drill a hole through one jaw of a Jorgeson wooden hand screw clamp. Make the hole bigger than the saw nut and center it over the saw nut as you tighten the clamp on the saw handle. Holds one side steady while you unscrew the other.
Some have mentioned using CA glue to glue nuts on both ends and using wrenches to remove the nuts - I always ended up shearing the CA glue joint.
Regards,
Mike Hamilton
Plainfield, IN
NOT CA, but epoxy...heat to remove bolts
Alan DuBoff
Re: NOT CA, but epoxy...heat to remove bolts
Kevin French, Antrim, NH
>Just C Clamp a block of wood to the back side over the nut and offset the clamp on the front side. They usually come off that way.
David Wheeler
>Okay. I think I get the idea.
The handle was in really good shape and I just wanted to be sure I didn't damage it in the process.
Thanks.
>Well, I wasn't going to suggest this as it is a bit aggressive, but after the other posts here I go.
What has probably happened is that the wood on the handle has swelled up an is actually capturing the nut. What I do in these cases is 'outlet' the nut. This is the opposite of inletting.
Take a sharp fine knife and gently go around the edge of the counterbored hold that the nut is inlet into. Removing a small amount of wood from around the hole will allow the nut to be easily remove. Use care as not to scratch the nut.
Stephen
Andrew Lunn
>I think the problem is actually just the opposite of what you suggest, Stephen. He says the nut and bolt spin in the hole, as opposed to being trapped by the wood. I'm sort of late, but what I would try would be to take a small piece of rubber like you can use to open a stubborn jar, or a piece of non slip drawer liner, and press that against the bolt head with my thumb, then gently try to turn the nut. A dot of oil on the center of the nut, around the threads, might help if it can penetrate.
David Wheeler
>Pinching the smooth bolt head with a small block of wood half worked.
I was able to loosen the screw to a point where it alone just spins. It is about half the way out or more. However, I can still tighten it to a point where the handle is completely tight; I just can't get it to thread all the way free.
Perhaps I'm wasting my time with all this. All I wanted to do was get the handle off; fully clean the blade; and send the plate to Daryl Weir to get sharpened.
