I can think of a couple things... *LINK*
Alan DuBoff
>Stephen,
It is possible that it was done intentionally, Foley made a carrier that would accommodate an arched blade as used on floor saws. But I believe the intention is to be able to start the cut in the middle of a section, so there are a few things that it could work for in that regard, however one would involve putting a (gasp) back on it.
That would be to use it like a stair saw to start a cut in the middle of a board, might be handy for repair work in that regard also, if one needed to start cutting in the middle so they can preserve the edge. Once an edge is broken it weakens a piece severely...*wink*
So, one way is to use it as a "gents stair saw" (tm).
Maybe another way to approach the task, without a back would be to create a saw the used a pull stroke, like a Japanese style saw. Small joinery pull saw could work.
I was thinking about a two man saw, but a small version that would be used by a worker with a handle on one end, and a smaller handle on the other, using like a hand plane or stair saw in function. I would still put a back, because I don't think you would have the precision which seems desirable to me with Joinery.
What advantage would it have over a stock rip or xcut saw? I don't know...to me working wood is just a removal process, not matter how it is done. You can chop it, slice it, cut it, tear it, and even beat or break it apart by the fibers...wood is fascinating...
The old saying, "When you have a hammer, everything starts looking like a nail" could be fitting. A smith uses heat and a hammer to solves problems, a sawyer uses a saw, a chisler (no jokes please;-) uses a chisel, a planer uses a plane...etc...
To me a real craftsman is able to use all of his tools, in all types of ways, some that have never been used before possibly...and have a good command of those tools to use them effectively (and safely;-).
I have also been thinking of small chisel type devices with saw teeth on them to use for cutting slots in wood for inlay possibly, and some do exist, but I have to lastly tell you that I recently saw in an old South Bend catalog, a device that was sold to undercut commutators, isn't Mica the plastic stuff they used? It's called a Mica Undercutting Attachment.
It's interesting as this same concept seems to be used for broaching on metalwork, to create square holes essentially. A file is really only a stiff saw when we think about it, and we can change the pattern even by texturing the surface.
To bring this back to sawing, there are many things that can be done with small saws, by using them in non-conventional ways. Devices one uses with an arm motion to cut/remove wood in that way is such a device. There is nothing that probably hasn't done by folks for ages most likely, a real galoot uses the tools at hand and often one is used for a purpose not that it was intended. As long as it works, I think it's all good.:-)
What is Mica, from page 17 (Mica Undercut Atatch)?
