24 Hours
>And that would be the time it takes for hide glue to dry. Given that most of that time is spent doing other things and given I have boards from the sawmill and don't need to slab out the boards from timbers, I can give you an idea of what it takes to make a drawer.
Preparation of the drawfront which is thicker, including ripping to width and cutting to length and planing flat probably 20 minutes. That includes plowing the groove.
Preparation of the drawer sides and back, same as above, don't need to take too much time as these don't show, so 20 minutes. Plow both sides, back is somewhat narrower and has no groove.
Preparation of the drawer bottom is another matter. If I am resawing down then it takes some time. I can get thinner boards from my sawmill, so with a good scrub plane about 30 minutes for the bottom. I usually make my drawer bottoms in two pieces oriented with the grain running from side to side with a butt joint. I glue the bottom up, in the groove when I glue up the drawer, it is the only clamp I use on dovetail drawers. They are self clamping. All glue joints are toothed to increase adhesion.
The blind dovetails on the front about twenty minutes, this includes marking out, sawing and chopping both sides.
The through dovetails, probably about 15 minutes to completion. I gang saw the tails first so I can cut down on time here.
Five minutes to fit everything up and 20 minutes to glue up, wipe of squeeze out and clean up the brush and rags.
Now I didn't include the time to prepare the glue, I used liquid hide glue. But these processes can be combined, especially if you are doing multiple drawers, the time can be somewhat reduced by doing all parts at the same time.
So how much time is that, well let me do the math, but just under 2 hours. But then there are breaks, distractions but I think the total working time is around that time.
This is in a perfect world when all your tools are where you expect them to be, the wood behaves, your clamps, if you use them, are in place, your tools are sharp and you hold your mouth just right, it can go quickly.
But it still takes 24 hours for the glue to dry, so if it takes longer to make the drawer, it will be ready tomorrow.
Stephen
