Re: Debunking "flooring movement"
Dave Mount
>Apologies to those that have seen this before, but it is germane to this discussion. I posted a version of this on the noisy side a while back, but I'll repost an edit of it here, because this thread keeps referencing the need to leave gaps at the edges of wood floors.
Before I get into the expansion thing, I wanted to comment on gluing flooring to the subfloor with a suitable adhesive. This does not stop a floor from moving and it is not the intent. The idea is to use a semi-flexible mastic (as Ellis suggested) that will help fill voids and prevent squeaks without creating stress from restrained movement. It is used in wider plank sizes because the wider the strip, the greater the spaces between the fasteners (which are only on the tongue side). So gluing down a floor with a flexible adhesive is not really the opposite of "letting it move."
Back to the "gap for expansion" thing. I find this an interesting piece of "conventional wisdom", because as I'll argue, the superficial explanation of it defies common sense. The fact is that wood floors don't (under normal circumstances) don't move as a unit -- the expansion is taken up by compression at each individual joint, not at the edges. Think about it; if the floor expanded 3/4" at the edges during the summer (and the expansion would be way more than that if it was a 15' wide board), it would pull the nails at the edges and it would never go back the following winter. Also, you couldn't ever install a floor with a border, because the border would be pushed apart when the floor moved. A direct observation is that (unfortunately) I'm still missing a few pieces of baseboard in the house and the gap at the edge of the floor doesn't change dimension seasonally, it's the same today as it was when I laid it (OK, I don't have a caliper on it, but no perceptible movement). Another example is at the door thresholds where I laid the flooring to within 1/8" of the threshold and caulked the gap -- nothing has ever moved, the whole thing is stable. If the floor was moving substantially at the edges, the caulking and/or the door threshold would have been pushed out.
Movement being taken up at the joints between individual boards is also why you don't glue the edges of solid wood flooring -- it would panelize the floor and it would start to move like one huge board.
So why does everyone say "leave a 1/2" for expansion"? Good question. Here's my belief of why it may be important. As I've explained, it is not needed under ordinary circumstances. But, it may be needed under extraordinary circumstances, i.e., catastrophic wetting of the floor. The power of expanding wood is incredible, and the amount a floor would expand if it were actually wetted to the fiber saturation point is way more than what would occur under normal seasonal cycles. Using figures from Hoadley's book, I calculate that a flatsawn red oak floor 15' wide would expand by over 12" going from 7% MC to 30% MC. An 80' wide hard maple floor (like gym or ballroom) would expand over 6 feet! I've seen pictures of things like gym floors that got flooded, and it's amazing to see the floor pulled up out of the subfloor and sitting there in "standing waves" as it curls in a sine wave to take up all the expanded width.
So how does this relate to flooring in a house? My thought is that a gap at the edge (and only along the long grain edge, obviously) is there so a catastrophically expanding floor doesn't push the walls out. Sounds crazy, but think about it. If there's a gap, then by the time the flooring edge reaches the sill plate, the nails holding it to the subfloor will be largely pulled from the subfloor -- not completely maybe, but largely. Being freed from the subfloor allows the pressure from the expanding floor to be taken up vertically by buckling. If the floor were still firmly attached to the subfloor, the pressure would be applied more directly outward to the sill plate. The same would be generally true for glued floors -- the flooring to subfloor bond would have to be broken before the flooring reached the sill plates.
I'll caveat all this by saying that it is the only explanation I've ever come up with to explain something that is otherwise nonsensical. I've never had this theory affirmed by anyone with any authoritative knowledge; but then again, I've never had it countered by anyone with any authoritative knowledge. I actually wrote to Fine Homebuilding and presented this argument after they had an article on flooring that had the "1/2" for expansion" bit in it, but they didn't respond. As above I argued above, just the existence of floors with borders completely debunks the idea that the floor is moving perceptibly as a unit under normal circumstances. So if not that, why?
Another possible explanation is that gaps were originally left simply because there was no need to fit it tightly when it would be covered by baseboards and the expansion thing just grew up on its own. However, I hate to invoke an argument that the whole thing is a myth if there could be a rational explanation related to expansion.
Best,
Dave
