A55 Smoothing Plane
Niggling questions...
Edward in Vancouver
>So I am now committed (!?) to my project (Gerstner style toolchest) and have surfaced and trued up my stock, and will be getting the stock resawn to the requisite 1/2" and 3/8" thicknesses that the project requires next week.
Assuming that I can work 8-10 hrs per week on the project (not including making neccesary jigs and replacing 'eaten" pieces...) How should I store my resawn stock? My garage is well insulated but not heated. Should I pile and sticker the stock and remove what I need only when required?
Surfacing. Assuming that I resaw my stock at 1/16th thicker than required, should I thickness it all to required 1/2" and 3/8" at one shot, or only thickness what I need for that particualr sub-assembly? The project will be broken down into various sub assemblies: Panel back and front, Carcass, drawers, etc. I'm figuring on one assembly per 2-3 week period.
And last one. I haven't chosen a finish yet for the outside yet, but during construction I will have an opportunity to finish the inside of the carcass. I was thinking of a plain-jane water based varathane for the inside, as no one will see this and it's only purpose it to protect. Should I be doing this?
When making the panels for the frame and panel front and back, should I pre-finish (outside and inside) the panels before fitting them into the frames?
Finish options? It's qswo, do I need a filler? Not thrilled with the aspect of a film finish, as I don't know how much abuse the chest will take, suggestions for some kind of an oil finish?
Re: Niggling questions...
ThomD
>"Assuming that I can work 8-10 hrs per week on the project (not including making neccesary jigs and replacing 'eaten" pieces...) How should I store my resawn stock? My garage is well insulated but not heated. Should I pile and sticker the stock and remove what I need only when required?"
Best case you should leave the stock where it will be when you finish the project. If that is the garage, so be it. Stickering may not be necesarry, depending on how different the storage place is to the environment the stock is so far used to. If it needs further drying, then stickering might be indicated. You must use straight stickers or the stock will rack. If the material needs to adjust (even the seasons changing could make that demand) there isn't any garantee your resawn and planed stock will remain true. You shouldn't really make a project like this with wood that is moving around as you go. And if the end case is complex it may not survive your environment. A shop should really be stable temp and humidity (not that mine is, but then I don't have solid wood shop furniture. Normally I get away with a little bad behaviour, but if I got distracted half way throught the project, and then had to delay a long while. Pretty much guaranteed to end up playing with cupped stock.
"Surfacing. Assuming that I resaw my stock at 1/16th thicker than required, should I thickness it all to required 1/2" and 3/8" at one shot, or only thickness what I need for that particualr sub-assembly?"
See above, but basically you don't make furniture in a variable environment using wood that is on the move. And you don't start truing the wood using wood that still has a way to go to be stable, unless you have a lot of time and room in the parts.
For isntance my shop isn't perfect but I make stuff for my house and I can be required to store parts in the house when I am not using them. I have wood for the kitchen table stored next to the TV at the moment, along with guitar projects. So those are the risks, not saying it won
Not mormally though if you have a lot of variability in the conditions in your shop it could help maintain dimensional stability. A clear water based with some wax would be cool.
"When making the panels for the frame and panel front and back, should I pre-finish (outside and inside) the panels before fitting them into the frames?"
Depends on the finish, I spray water based and sometime you don't need to pre-finish, but in general I would try to prefinish, you may have to touch up a few ares to leave room for glue.
"Finish options? It's qswo, do I need a filler? Not thrilled with the aspect of a film finish, as I don't know how much abuse the chest will take, suggestions for some kind of an oil finish?"
White Oak? I would prefer something that didn't yellow, but that can be touch lacquer, or an instrument grade water based. If I shoot regular water based I normally tint it a little to get rid of the blue, but either way that might end up looking a little yellow.
Edward in Vancouver
>Thanks Thom. The stock was purchased kiln dried and had been stored at the lumber yard a good 4 mths prior to my purchase. Nice stuff, very little twist or cup, and only 1 knot in the whole 17 bd ft.
To ensure no snipe while surfacing the stock on my cheap hand-me-down little Delta Lunch-box thicknesser, I tossed the the sheet metal ramps it came with, and made a 48" by 12" torsion box. This was made of two sheets of 1/4" fir ply and strips of 1" mdf on edge spaced every 4 inches on the length. This sits on the bed of the thicknesser and is secured at either end. No snipe. Not even on that massive 4' chunk of 8/4 oak. Edges were jointed by hand. My T.S. would probably take one look at that 8/4, give up and wimp out without even trying....
Maybe I should bite the bullet and choose a good danish-type oil now, as I'll be constructing the frame and panel back and front first.
ThomD
>I had one of those deltas and they were remarkably good, better than the big boys on stock destined for guitar soundboards. I tossed the sheet metal, and usually didn't bother with the supports at all.
Good luck with your project, quarter sawn wood should make things easy.
how to store wood and more
Robin Corell in Atascadero, CA
>I am just finishing up on a silver chest with similar sized drawer parts. The client had asked for regular updates and pics of the construction process. some days there was not much to take pics of, or so I thought. As it tends to happen this time of year we had a periond of unseasonably warm day time temps with low night time temps and we all know that this can really be harsh on stock in an un conditioned shop. at the end of one of these days I was about to leave the shop and as I turned to look back as I turned out the lights I changed my mind and went back to snap the attached pic.
Without really thinking about it I had turned the thin stock for the drawer fronts and sides(not in the pic) on edge. this is something I learned as an apprintice and is something I do without thinking. When working with thin stock I was tought that there are two ways to store stock to prevent warping. If the pieces are the same size you can stack them flat without stickers with something else on top. with this method the only area exposed to absorbing moisture is the thin edges and both are exposed so the change will be minimal and equal. the second method of storage is shown in the picture and it is on edge with space for air to circulate. this method is appropriate for wood you will be working with the folowing day or two, but can result in movement for long term storage on wide stock.
As I had mentioned earlier I have a pir of gerstner boxes. One is made out of poplar covered with black naugahide and QSWO drawer fronts. all the stock for this box is 3/8" and the inside is unfinished. The other is all QSWO with a walnut panel in the front. this box was not made by Gerster but is patterned like one with the only exception being the raised panel in the front.All stock for this box is 7/16" and it is finished inside and out with varnish.
On both of my boxes the back panel is solid with the grain running the long way. I have always thought this odd as the grain on the sides is 90* to the back. this means the joint along the back corner is end grain to side grain and one board moves a fair bit with te other not moving at all. The box made by Gerster was made more than 60 years ago and has been in service the entire time. For me it is not my primary box but I use it at least once every day and it is not showing any signs of wear. My oak box is larger and gets used more often with the only wear being a significant crack on the tounge that joins the end of the top tray to the side. this is a cross grain tounge and groove joint. I ran some dowels through it when I aquired it in 1994 and it has held since then, though this too is not a correct fix.
On the pair of jewelry boxes I made that had drawer details similar to a Gerstner I made a dovetailed carcase with a frame and panel back and no front. the detail I never cared for about these or the gerstners is that the drawer guides run cross grain. this means the screw holes need to be elongated and allow for movement. while neither of my work boxes have showed problems in this area there are a couple of broken drawer guide ends that are missing as they eventualy came loose due the the cross grain issue. For the silver chest I am currently finishing up, all the sides are frame and panel with the drawer guides glued into blocks of wood and those are glued and screwed into the side rails with space between each. If this sounds un clear and you are interested I have pics I can post.
I like to toss a couple of coats of finish on panels prior to glueing them in and when I do this I often finish both sides, particularly if I know it will be several days before I get all the panels glued into their frames. Other than that I never bother with finish on the inside of cabinets. One exception is sometimes on the sides of small drawers and this is only to help keep them free of grime as small drawers are often removed and handled unlike a large drawer.
For finish I tend to use a lot of General's HP water based Poly acrylic. it performs very similar to lacquer other than the initial grain raising. I find that after a month this is a very tough finish and with the UV inhibiters it tends to not yellow like lacquer. I brush all my finised due to a very small shop. I find that the extra time of brushing is compensated by not having to rid the area of dust and set up a spray rig. The General's HP is suitable for either brushing or spraying.
Robin
