Re: Next you need a Scythe
ThomD
>I think reel mowers are like planes in the sense that you may find you need more than one.
I recomend the gardena if females are involved. I have four females on the property and that is all they want to use. It has lots of plastic parts, but it cuts with precision, and is so light that I normally just pivot and it floats to the next row, through the air. It's great if you have to cut around a lot of stuff and floats up hills. On the other hand one does notice the extra laps on straightaways.
The LV silent mower looks like it hits the same buttons.
http://www.leevalley.com/garden/page.aspx?c=1&p=51117&cat=2,2160,51170
In order to have greater speed over larger open areas, I later bought a 20" mower. I like it OK, it is really too hard for my wife to push. She is very athletic, but it just has too much resistance for all the starts and stops. I have a lot of weight to put behind it and can keep it moving. If there was a wide Gardena type mower it would probably suit us both.
The LV 20 incher is similar to the Scott 20 incher we have. It's lowest mowing height of just under 2" is too high. It isn't just a mater of how high the grass is when you finish but whether there is enough feed pressure to cut well. With the scott you can release the adjustment lever and let it fall to a lower more reasonable position. I don't really know what they were thinking. If one has a cloddy undersurface to the earth, the 20 inch mower's extra wheel do ride really nicely.
We also have a greens mower, and that's a whole other thing, a finishing plane if you like.
Between the two you mention, I would strongly recomend the 18", or the silent mower if you move in that direction. I haven't used the 18" but with the 1/2" cut not available on the 20 incher, and the difficulty of pushing the 20 incher...
One thing about push mowers - reel mowers come in power versions also so "reel" doesn't = "push" - is that they are really only good for cutting grass and clover, etc... A lot of junk that can start in a lawn is not amenable to their touch. This leads to Scythes, brace yourself. Actually they are more interesting and work better anyway.
As far as all the enviro hogwash is concerned, reel mowers create some problems in the sense that they aren't compatible with lassez fair attitudes to weeds and so forth. I actually don't use pesticides because I like to do sensible stuff like juice the dandelions, but the reality is that good no pesticide lawn practices are not made any easier with a reel mower. I start to look with distain on people who are just letting their weed grow in carpets because I can't just buzz saw through the weeds as I might with a power mower. However while people complement us on the size of our yard, it is still small enough that if one is healthy a reel mower is probably less trouble, you don't have to be on a CO2 or fitness kick to use one.
So far I haven't found a grass catcher that works with a reel mower, and that I like. They are all more of a pain than they are worth. In the old days the mowers came with serious, if heavy steel boxes that stayed put and stopped the mower topeling rearward. The new ones seem like afterthoughts.
I would buy the lap system, but it really is more like the burnisher for a scraper, than a sharpening system. It will refresh the reel until it dulls it completely. You will get past a few years though without needing to do anything too drastic. Better still, develop a deft hand with a file, and when that ends up distorting the reel you need a metal lathe with a tool post grinder.
