Cabinet Master Clamp Failure
David Cockey
>I broke a Jorgenson Cabinet Master clamp last weekend. I was tightening it when the diecast "box" around the clutch plates broke. Anyone else have a similar failure?
I have several of the Cabinet Master clamps as well as a number of K-Bodies. I've prefered the CM's but I will probably stick with K-Bodies in the future.
Re: Cabinet Master Clamp Failure
Re: Cabinet Master Clamp Failure------WebKitFormBo
Tony Sade (Charleston, WV)------WebKitFormBoundary
>The early versions of these clamps had lots of failures, which have since been corrected with some re-engineering of some of the parts. (Not sure if it was the plates or the box.) I had a couple break. THe guy from the Adjustable Clamp Company posts over on the Woodnet forum-they're real good about shipping out replacement parts.
jluley@adjustableclamp.com
http://www.adjustableclamp.com
I'm sure he'll fix you up.
HTH, Tony
No idea what the "WebKit. . " stuff is
>Or where it came from.
Re: No idea what the "WebKit. . " stuff is
wilbur
>Do you use Safari? The Safari browser uses the "WebKit" engine (check out webkit.org). Unfortunately, there's a bug with the WebBBS software that powers WoodCentral that causes WebKit+gibberish to be added to the end of the fields in the "Post Response" page on occasion.
For any computer geeks out there, here's a report of this bug.
http://bugs.webkit.org/show_bug.cgi?id=16122
Second Contacting jlulley
Mike Fitterling
>I had several of the old CMs break. There was a casting flaw in many of the old ones that are silver. They discovered the flaw and now the good ones are black. I have contact "Clampman," as he is known at Woodnet, and he has always taken care of me, sending out replacement parts at no charge. I even have a spare now in case my last old one breaks. I have had zero problems with the black castings.
Cheers,
Mike
