ADVERTISE HERE - FREE TRIAL
Cutting a scratch stock blade
Stephen in Ottawa
>I've just gotten around to tuning a 5/8" hollow that I need for a current project. The sole is slightly concave and I want to take down the toe and heel with a scratch stock. I have some old bandsaw blade as well as scraper and saw blade.
I lack any kind of rotary tool so what's the best way to cut a piece of the steel? I guess I will use files to actually shape the profile, though I haven't tried this on a bandsaw blade.
Regards,
- Stephen
Re: Cutting a scratch stock blade
Files will work, but...
Scott Burr in Ben Lomond CA
>It will be slow going. Sounds like a good excuse to get a new tool!
"RJ" Whelan
>I cut old saw blades with a cold chisel.
Once I have the rough shape (I usually cut several blanks at a time) I anneal the blank in the oven.
Then I file to shape.
Then harden with a torch (I use oxy aceteline - sp; because I happen to have this equipment - I have heard that MAPP will get hot enough as well) and quench in 30W motor oil. This may not be the ideal way to do this, but it's worked fine for me.
Lastly I flatten the hardened cutter and clean up the cutting edge with slip stones.
One thing to avoid (if possible) is agressive resharpening in the middle of making a bunch of moldings. If you remove too much material your moldings may not match at the mitres (DAMHIKT).
Good luck .......... rj
paul womack
>I've had good results with a 32 tpi hacksaw blade. If the stock is too hard to hacksaw, it's too hard to file!
BugBear
Todd Hughes
>I've made many of these and all I ever did was scribe a line in the steel with the edge of file and then put the steel in the vise and bend it over with a hammer till it snaps along the scribe. Takes about 45 sec. to do and only needs minimal clean up to the edges with a file or grinder...Guess there are harder and slower ways to do it but I never spent much time thinking about it.....Todd
Andrew Lunn
>Depending how slightly the sole is out, it might even be quicker to just wrap some sandpaper around a dowel and use it like a jointer to get the sole level again--or use a carving gouge to get it close then finish with the sandpaper/dowel. Good luck!
