The die is cast
The die is cast
The die is cast
Edward in Vancouver
>I've finally committed to my new project, a Gerstner style tool chest. Bought about 18 bdft of qswo about two weeks ago and now have started to flatten it and cut it into manageable chunks. Took me 3 drafts on paper on how to cut the stock up. Monday I'll take it to a friend's to have it bandsawn into 1/2" and 3/8" boards
Re: The die is cast
More, more ! . . .
steve mackay
>Keep putting off building my Gerstner " roll-away ". Fear mostly ! C'mon, push me over the edge !
Re: The die is cast
Re: The die is cast
Robin Corell in Atascadero, CA
>It may be hard to see much detail in the pic so I hope you have a good imagination. The pic is of a jig I made to hold the hand piece of my fordom grinder mounted with one of those mini gyro saw blades. It is effectively a mini table saw and is set to cut a very narow dado in the sides of drawers so I can use sheet metal for the bottom. I used this on a pair of 8 drawer jewelry cases I made. I used my Gerster boxes as templates for many of the details and this is one of thoses details. I found I could place the drawer bottom 1/8" from the bottom of the drawer and the thickness of 8 metal drawer bottoms was just slightly more than one 1/8" sheet of masonite. that gave me an interior gain of 7/8" plus I never feel comfortable with only 1/8" of meat on the outside of a dado for a drawer bottom so I figure that saved another 1" or effectively another drawer of space.
I found a local sheet metal guy with a shop behind his house who cut 16 drawer bottoms for $30 and a six pack. I think it was 28 guage. The saw had to be shifted slightly as the kerf was a few .001 shy and all the boards needed to be run throuh a second time and then they fit nicely. once the felt is installed you can not tell the bottom is sheet metal.
A Gerster style box is a challenging and rewarding project. it helps to have one near by to look at. If you need info I have two I can send pics of.
Robin
