Snowshoe bending How It's Made
ThomD
>How It's Made had a short tonight on how to make snowshoes. The first step, once the stock was 4S was to install a metal strap with brackets at each end that supported the toe during bending. This compresion strap was necesarry because, among other tings, the stock was probably sawn cross grain. The stock and strap went into a full length steamer, and after 30 minutes a piece was withdrawn and wrapped around a metal form. This was a fully round shape, so the tail end was scarphed and overlapped. Once the basic shape was bent and a spacer inserted the toe was inserted into a brake and the toe deflection was pressed in. This was done without any apparent additional steaming.
I should note that during the initial profilling of the strip, the toe had been reduced in size for easier bending. The one point of interest was that when the support strap was removed from the toe, there was a lot of grain that had lifted on the outside due to grain run-out. This was agressively ground down, so that the overall thickness was probably in the traditional range of 3/8". The machinery didn't finish things up with a thicker toe, but it made it possible to use less optimal wood. Not to say modern wooden shoes aren't durable, but when I first saw the reduced section in the traditional shoe it looked pretty thin. In comparison it seems more than enough now.
