Chisels for making molding planes
Dave Mount
>Well, last Friday I finally broke down and bought a (wood) lathe. I just got tired of trying all kinds of workarounds to make round tool handles. I also got tired of drueling over all the nice handles I see posted here (you know who you are. . .).
The first project was some handles for two chisels I made from O-1 tool steel, pictured below. The upper chisel is a 1/10" chisel which I ground down from a 1/8" O-1 blank (you are looking at is from the side, obviously). This chisel is intended for reaching up through the mouth of molding planes to remove the waste after the bed and breast lines are cut. It looks kind of like a mortise chisel, but it's for paring; I made it "deep" to give it some rigidity (1/10" is pretty narrow), but it's ground at a little under 25 degrees.
The lower chisel pictured is a 3/4" wide bevel edge chisel. What's different about this is that it is only 1/8" thick, which allows you to pare down the bed of the plane from the escapement side (assuming the escapement is sized for a 1/8" thick iron).
The mallet is just hanging around contributing nothing. You can tell a lathe newbie because he's running around the shop trying to think of anything round he can make. It's hard maple, and I see the camera was kind enough to highlight some places where my sanding did not cover my poor turning technique.
I hardened the chisels by heating them in my forge -- I wanted to get the bulk of the blade heat treated and I didn't think I could get enough of it hot in the shop using torches. They were tempered in the kitchen oven at 400 F, which should bring them in circa 62 Rockwell. Pic following tempering follows.
The handles are turned from a piece of Australian lacewood that I picked up when I was in Australia (east coast) a few years ago. I went to a lumber dealer to see the woods for sale (strange to see the "imports" of cherry and walnut. . .) and was looking for a little something I could stick in my luggage. There was a piece of blocking laying in the warehouse roughly 2" x 4" x 3' that was clear QS lacewood. I asked if I could buy it and the guy just laughed and said "take it." Part of it I resawed into 1/4" pieces and made door panels for a bath cabinet. The rest has been laying around the shop looking for a purpose -- this seemed as good as any.
The brass ferrules started life as flare nuts that I ground the hex flats off of and polished.
Expect to see more tools soon -- I'm on a newbie high.
Best,
Dave
