We value your privacy.
>I just returned from a week in Phoenix and brought back a couple of cactus skeletons. I think that they look kind of cool, but would like to think of something to do with them that might make a neat display. I am definitely artistically challenged and thought that someone here might have some ideas that I could borrow to do something with them. The ruler is not too clear, but it is 14 inches long.
As an aside, it sure was hard to go from 90 and sunny to 30's with 3" of snow in the same day ;-(
That longer piece, with the crook in it, struck me as resembling the arm of a desk lamp--with the bulb going on the end of the cactus that is to the right in your photo. I don't know if it is already hollow up through the center or not, but maybe you could bore up through there and feed a wire through to do just that. Install a bulb fixture on the end and make a neat base, and a hood/shade, and you'd have a very unique and delicate little lamp for your desk.
FWIW, I also liked the previous two ideas from Scott and Bob.
>I had thought of that, but none of it is big enough to make a pen barrel. They are about 1/4 inch thick and 2 1/4 in diameter, fairly fragile and hollow.
I also saw some of the rods that go through a saguaro (but was unable to get any this time) that look to be pen sized. Not sure what the texture or grain pattern would look like, but they might be a good thing to try as a pen. I will have to see if I can get some. Thanks for the idea.
>That is a very good idea. Will have to give it more thought. They are hollow already, so the cord would be no problem. They are a bit fragile, but the other idea of stabilizing them with super glue or epoxy might work. Whatever I do, I will post a picture (if it works out ;-)).
>looks to be 7-8"? Wrap the one end and the sides with masking tape and pour some colored epoxy from the "top" into the cylinder. Insert a hook or other hardware and use as a pull or handle. 7-8 inches is probably to large for a ceiling fan pull, just a thinking out loud.
>I've made pens from smaller pieces by casting them in poly resin with brass shavings and knife handles the same way. Texas Knifemaker's Supply has blades with mostly round tangs and the rest of the needed parts if you don't want to make them yourself.
>MinWax makes a wood hardener. I have used it to reinforce cedar when I thought it was not going to hold a hinge well, seemed to work, but I don't know much more about it than that.
